Old 11-04-2008, 09:38 PM
Hellbringer is on a distinguished road
Extended X2 Mill Base
Hi Guys,
I need some opinions. i am working on building a new base for my x2 that is bigger and more percise. here is what i have right now
the travel is
x=17"
y=12"
with a 24"x8" table.
base and table would be made out of polymer cement
all axis are on linear motion ball bearing rod and blocks
i am looking for suggestion on another why to contruct it or flaws i dont see
thanks again mike
Old 11-04-2008, 10:15 PM
austin.mn is on a distinguished road
I would definitely flip the bearing on your X axis. That way the area under the milling cutter is always supported. The way you have it now as you move to the left or right you don't have any support under the milling head.
Old 11-04-2008, 10:51 PM
alexccmeister is on a distinguished road
How about the saddle? Is that polymer as well? Look thin for polymer. I think you may get better result with an X2 style saddle. More solid. You need thick section for polymer to work well. Overall interesting. Love to see how it turns out.
Old 11-04-2008, 11:32 PM
Ahh that makes sence.... thanks i hadnt though of that
no the saddle would be aluminum. just the table and the base would be polymer.
Thanks again Mike
Old 11-05-2008, 08:01 AM
kawazuki is on a distinguished road
No worries of differential movement between polymer, aluminium table and steel rails?
Old 11-05-2008, 04:51 PM
One of these days I am definitely going to have to build a polymer machine. I saw the pictures of the one on the CNCcookbook website that just looked incredible.
Keep us posted on the progress.
Austin
Extended X2 Base Hellbringer Benchtop Machines 3 06-12-2008 02:19 PM
New X2 Mini Mill Base Harlow Product Announcements & Manufacturer News 428 07-22-2007 11:36 PM
Building a CNC mill based on X1 parts / extended axis kits Qwerty256 Benchtop Machines 11 04-28-2007 06:05 PM
Extended base for the X2 CerveloRod Benchtop Machines 0 05-30-2006 04:44 PM
New H/f Micro Mill Extended Y Base With Thk Linear Rails heilcnc General Metal Working Machines 0 04-17-2005 06:05 PM
