| Horst007, What are you going to use it for? Are you limited on space, for $5,500.00 you could get a older full size CNC and retrofit the controls. If space is a issue you would be better of getting a RF45 clone and having it converted if you can't do it yourself. Jeff... |
| I am planning on putting the machine in my basement workroom for comfort of course. I can spend up to 8000, but I want it in my basement. I will be machining aluminum mostly. I have heard they have issues with the z depth being correct when drilling, and that multiple tools in a program is a real pain. |
| The main issue is keeping the Z axis in line if you need to change to a tool that is not the same length and the entire Z needs to be raised or lowered. Adjusting the Z position beyond the quill's range would require you to loosen spindle head bolts and in doing so lose Z alignment. It is possible to modify the CNC Junior's column in order to maintain Z axis alignment, however since you have the budget a square column mill would really be a better solution. What kind of parts will you be machining? Jeff... |
| It would be crazy to buy the junior if you have an USD 8,000 budget. Take a look at Tormach or Industrial Hobbies. An extended quill in a milling operation is not very stiff. The cnc junior is a dinosaur. If you already have a round column drill/mill and plan to convert to cnc is one thing, but to go out and buy one specifically for cnc work is just crazy. Phil ![]()
Especially if you have an outside access, hatchway. For 8K usd you should have a hell of a machine. Mike.
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| Tags |
| cnc junior by cnc masters |
| Need Help!- cnc junior (cnc masters) | pmesilver | General CNC (Mill and Lathe) Control Software (NC) | 1 | 06-27-2010 07:01 PM |
| MV junior problems | CNC2NUT | Mori Mills | 1 | 09-23-2008 09:10 PM |
| Mori Seiki MV Junior | TCSpooner | Fanuc | 4 | 11-09-2007 12:50 AM |
| Help needed with Mori Seiki MV Junior post | Baxter | Post Processor Files | 2 | 12-12-2006 04:59 AM |
| Help for a Junior Project | Epik | General CNC (Mill and Lathe) Control Software (NC) | 0 | 03-02-2005 03:19 PM |
