Hi all, I have just fitted the ballscrews and steppers ( x and Y ) to my mill and i'm getting some backlash. the mill is a RF45, i have class5 screws and nuts, 2 angular contact's at the fixed end's that are preloaded. they have no play and don't move any where. the nuts are fixed in there mountings by 6 screws and they don't move ether. both steppers are 960oz, with olden couplings? to the screws. when testing for backlash..... X .02mm/.03mm, Y .04mm any idea's where this backlash could be coming from? thx in advanced. |
| Hmmm, I was thinking that in order for the nut to be preloaded it was a double nut. My bad. I know the double nuts are expensive and I surely can't afford those. If yours are supposed to be zero backlash I wouldn't have a clue to find that slack you have according to the info you provided. Rick |
I believe the proper term is it has been fitted with oversize balls to get to zero backlash. When we talk oversize, we are talking .0001" oversize balls.They keep going up by that amount untill there is zero backlash. It can be more expensive, but if you have the room and the money, I like it better than the oversize ball route. Just my opinions of course.
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
Alex |
| are you sure your backlash is not coming from the motor itself? I know my small 269 oz steppers have a bit of backlash in them when they change directions. it takes about 3 steps to fully change direction within the motor itself. |
#10
| TOTALLYRC, i'll have a look at Vince's log. thx i had a little play with the X fixed end and found the A/C bearing is sitting flush with the bearing holder. so i faced off a tho or 2 so when i put the holder back on it would make dam sure the 2 bearings are being pushed together. that should make the outer of the bearings nice and tight. only thing is, i dropped my DTI and snapped the end off so a cant do any thing till monday.Fixittt. i will have i look at the motor when get a new DTI |
#11
| The way to measure backlash that is inherent in the nut/screw/table interface is to put the tip of an indicator held in the spindle on a vertical face (side of a vise, angle plate, whatever) then grab the table and shake it back and forth. You'll find out in a hurry how much slop is in the axis. I just totally rebuilt a retofit RF45 that utilizes Thomson preloaded ballscrews and servos. I bought it secondhand from a guy that didn't know the difference. When I disassembled the X and Y axes, I discovered that the builder had not locked the nuts to prevent them from rotating in their mounting block. Good components do not make up for poor implementation and attention to detail. The X and Y axes went from .008" and .006" backlash respectively to .0015". Most likely this is being introduced by the bearing and not the screw/nut interface. Regardless, I can live with it now. Joe |
#12
| Where/how did you measure this? Phil |
| Backlash or motor tuning problem? How do I test for backlash? | Brian Queen | Mach Mill | 8 | 03-10-2008 04:35 PM |
| Help with backlash | wdp67 | Benchtop Machines | 2 | 09-06-2007 12:16 PM |
| Servo idea - elimated backlash - zero backlash ! | synthetiklone | Linear and Rotary Motion | 6 | 12-06-2006 02:35 PM |
| Backlash | Ed_R | DIY-CNC Router Table Machines | 16 | 03-17-2006 02:30 AM |
| Backlash Nut !! | craftech | DIY-CNC Router Table Machines | 5 | 12-07-2004 12:14 AM |
