Old 10-11-2008, 12:56 AM
Peter Gibbs is on a distinguished road
Dyna Myte 2400 mill
Hi all we have just bought an old mill Dyna 2400. It is working and has abook but no software.
We would like to do some engraving with it.. Is there any one who could help with advise as to suitable programs and or conversions for this machine. Kind Regards peter
Old 10-11-2008, 01:12 AM
jalessi's Avatar
jalessi is on a distinguished road
Smile
Peter,
Dyna 2400 mechanicals are good the electronics are junk.
Order a G540 Gecko
http://www.geckodrive.com/product.aspx?c=3&i=14469
Order a 50 volt power supply
http://tinyurl.com/2na2pt
Three new steppers if needed.
http://www.kelinginc.net/KL23H276-28-4B.pdf
The retrofit is not that hard and well worth the time
Jeff...
Old 10-11-2008, 03:12 AM
Jeff thanks for your reply, are new steppers nessesary if the old one are working?
thanks for the info cheers peter
Old 10-11-2008, 03:21 AM
Jeff all this info is for a mate who is just starting out , I take it that once having installed the upgrade one will need a cad cam package to drive it all and an NC link can you recomend this as well cheers Peter
Old 10-11-2008, 07:02 AM
TOTALLYRC is on a distinguished road
Post
These are software that you use to run the machine.
www.machsupport.com Mach3
http://www.linuxcnc.org/ EMC2
http://www.dakeng.com/ Turbo cnc
This is an integrated software and hardware combo that doesn' need a breakout board. It also converts files into gcode (cam?)
www.deskcnc.com Deskcnc
There are others.
The steppers may or may not work. If they are still good and you can wire them bipolar, try them. If you need more performance buy new ones.
Old 10-11-2008, 07:15 AM
Thanks again cheers Peter
Old 10-11-2008, 10:50 AM
cyclestart is on a distinguished road
The company still exists http://www.dynamechtronics.com/supports.html but may not offer much help for old machines. Nothing lost in sending off an email ?
There is also a yahoo group.
Here's something from the Mach forum, not sure exactly what to make of it
http://www.machsupport.com/forum/ind...pic,630.0.html
I have no knowledge of how the software is loaded in the control or where to get it. The original software is limited to approx 900 lines but otherwise looks usable.
Just tossing out a couple of things to research in case you want a cheaper way to get running. It is very possible the original electronics is nonfunctional or just plain junk as jalessi noted.
Anyone who says "It only goes together one way" has no imagination.
Old 10-11-2008, 11:33 AM
jalessi's Avatar
Smile
Peter,
You may also want to take a look at the Vectric products, they are simple to use and run on Windows.
http://www.vectric.com/
You may find EMC2 difficult if you are not Unix or Linux savvy.
Mach3 is Windows XP based and very good.
Spend some time reading on the Mach3 forum, it will help a lot.
You may not need to replace your steppers like the other forum members suggested, try them first.
The older round steppers do not develop the power that the new style square units produce.
If they still perform well you have saved some money.
I think that using the antiquated DOS based software will be frustrating and limiting, however it might still be a option.
Enjoy the challenge, its addictive.
Jeff...
Old 10-11-2008, 07:44 PM
genlemen thank you for your replies Ill see what I can do cheers Peter
Old 10-12-2008, 07:02 PM
Alex_Cole's Avatar
Alex_Cole is on a distinguished road
Here is my thread about my DM2400 mill. I converted mine over to servo drive. I now seem to have all the bugs worked out.
Dyna 2400 Mill update NOT DIALUP FRIENDLY!
Alex
AC
Has anyone seen my pillow?
Dyna Myte 2400 Manuals azbret Want To Buy...Need help! 2 05-23-2011 04:26 AM
Newbie- Found an old Dyna Myte 2400 mill...what do I need to get it going? EMS_CNC Benchtop Machines 3 09-20-2008 05:08 AM
Problem- Dyna Myte 4400 Mill echostar DynaCNC 3 06-30-2008 09:23 PM
DYNA MYTE 2400 helfriwj Benchtop Machines 4 04-01-2008 11:45 PM
Need Help!- Need Dyna Myte 2400 controler helfriwj Benchtop Machines 1 02-13-2008 03:34 AM
