Talk about fun loading this in my truck off a loading dock, and then into my garage with only two pallets, a two wheeled handtruck, and a ratcheting strap. It's still mounted to the pallet, but mostly cleaned up, and the bearings were broken in last night. Today I got in my basic tooling: 6" horizontal Phase II rotary table, some collets, 2 and 4 flute end mills, parallels, and a few other little things. I'm still waiting on my 4" screwless vise, and clamping kit. I have a few other things I need to pick up in the near future, fly cutters, slitting saws, boring kits, etc. I think this will give me a good start though. In any case, does anyone have any recommendations for tweaks or setup beyond the basic clean, lube, backlash setup? Also, is there a good online source for DOC and speed settings for different materials/cutters? |
| doc a good rule of thumb should be half the diameter of the mill you are using as for feed and speed it all comes down to the material and how the machine takes it also the type of cutter you will use (carbide, coated, hss) and the number of flute on the tool. this next chart should help you out so to calculate your speed the basic formula is (4xsfm)/Diameter of the tool (if you work on a lathe it will be the diameter of the part) = rpm now to calculate the feed its chip load per tooth x N of tooth x rpm so lets say you have a material that as a sfm of 200 and a tool of .5" (4x200)/.5" = 400rpm so you feed is if you have a chipload per tooth of lets say .002" and 2 flutes 400x 2 x.002 = 1.6"/min but remember all those are affected by the size and power of your mill a 2.5tons mill with a 7hp motor can chew alot more material the a 400pound mill with a 1hp motor, the same goes for the quality of the tool. those will also affect the longevity of your tool since using the max feed will get the job done faster but will also kill you tool faster
__________________ The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne Last edited by ataxy; 10-10-2008 at 02:47 PM. |
| Harbor Freight # HF93885 vs. Grizzly G0463 | yz400fer69 | Benchtop Machines | 16 | 02-07-2010 09:51 AM |
| DRO Questions for Grizzly G0463 (X3) | nsiters | Benchtop Machines | 14 | 05-27-2008 01:00 PM |
| Need Help!- Grizzly G0463 Questions | nsiters | Benchtop Machines | 17 | 03-24-2008 05:19 PM |
| Any opinions on the Grizzly g4016 lathe or other Grizzly lathes? | DublD | General Metal Working Machines | 3 | 11-26-2006 01:23 PM |
| WOOHOO chips in pan, Galil servo tune? | Karl_T | CamSoft Products | 3 | 05-27-2006 08:51 PM |
