Old 10-09-2008, 06:50 AM
Job Job is offline
Job is on a distinguished road
Help choosing a small CNC mill
Hi all and thanks in advance for your help,
To introduce myself quickly, I’m new to milling (CNC or not), but I’m an engineer and would like to work home on a project (that is totally unrelated to my work).
I would need to mill some complex parts with a CNC machine (since it is prototyping and I will sure need many tries, manual milling would take way too much time) that would.
Describing quickly my needs:
- Most in brass, some in hard steel (0.5 t0 1 mm sheets to cut springs).
- Flat parts, would be approx 40 x 40 x 10 (thick) mm.
- Accuracy needed is approx 0.1mm, better accuracy would be very welcome as it would avoid refinishing parts to avoid friction. Accuracy is much more important on brass than steel.
- Milling time is not a factor.
- Machine fatigue is not a factor as it’s prototyping, part size is extremely small.
- 4th axis would be useful but is not required. Typically having a 4th axis as an option that could be added afterward would be perfect.
- I’m in UK, so is the machine is in US (I guess most are), a light one would be much better to avoid deterrent shipping cost.
- Price is of course a factor lol.
- As I'm a newbie, an easy to use machine, with not too much software cost is better !
Old 10-09-2008, 08:58 AM
ataxy's Avatar
ataxy is on a distinguished road
whats your budget?
The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
Old 10-09-2008, 09:18 AM
Job Job is offline
Thanks for your answer.
I would say "what it takes" as I can afford to put serious money, but would prefer to avoid if possible.
Typically 5000 USD would be fine, less better, but it would be stretched 2 or 3 fold in case I really need.
Old 10-09-2008, 10:06 AM
ataxy's Avatar
well if you want to stay in the 5k i would say the syil x4 or that new kx3 that whe are starting to ear about but this will give you only a machine without tooling now since you say you would be able to spend more if you add in a 3k more you will get the cutting fluid and 4th axis and some tooling, so basically you could go with a tormach tooling system a good set of coated hss cutter or else if really you want to spend more and dont care about the price then you can go with a tormach, industrial hobbies, or smithy witch are going to give you way more stiffness and precision then a x4 or kx3 but it does come with a price tag that is double that of the x4 and kx3 if you so go with the small mill i highly, and this is a pov, that you get a nice set of carbide cutter to do the finishing of the part, some will argue the need for it but like i say it a personal point of view.
- Most in brass, some in hard steel (0.5 t0 1 mm sheets to cut springs). all the mention mill will be able to work those material
- Flat parts, would be approx 40 x 40 x 10 (thick) mm. all the mention mill will be able to work those material
- Accuracy needed is approx 0.1mm, better accuracy would be very welcome as it would avoid refinishing parts to avoid friction. Accuracy is much more important on brass than steel. all the mention mill will be able to give you those accuracy but the larger mill will be able to give you the result you want in faster time.
- Milling time is not a factor. go for a smaller machine and get better tooling
- Machine fatigue is not a factor as it’s prototyping, part size is extremely small. again a small machine could do the job here and give you more money for better tooling
- 4th axis would be useful but is not required. Typically having a 4th axis as an option that could be added afterward would be perfect. thats your call but here you would get a stonger and better fourth axis if you go with a bigger machine as the rotary table would be bigger and of better quality, forget about putting a 8inch rotary table on a small mill
- I’m in UK, so is the machine is in US (I guess most are), a light one would be much better to avoid deterrent shipping cost. yes
- Price is of course a factor lol. if its is, again you will get a better work hose out of a bigger one but with proper setting up and tolling the small mill can give you really good result.
- As I'm a newbie, an easy to use machine, with not too much software cost is better ! the software to operate any of those machine is not the problem here as mach3 wich operates all of those machine is only ~150$ the price of software come down to your choice of cad/cam
Reply With Quote you want price quote or to reply with quote of what you said
Old 10-09-2008, 10:25 AM
Job Job is offline
Thanks a lot. Have been spending hours looking and did not find this one (which looks better than all I have already found)
I have just found this website, I don’t know if prices are ok (take into account 20% VAT), but at least, it’s just 200 miles away from where I live.
I have seen the KX1 also, since it’s only small parts (the size of a coin), I guess it would do the job, no ?
http://www.arceurotrade.co.uk/Additi...Hobby-CNC-Mill
Since I do not need to mill more than 1 cm of thickness is there any engravers that would be able to accurately cut brass and steel?
Would the software give with the machine support a 4th axis?
Old 10-09-2008, 10:38 AM
ataxy's Avatar
yes mach3 supports up to six axis
the kx1 is a relly small machine and will definitly show more sign of flex wich can in turn affect the precision of your part, again better quality tooling will help but up to a point due to the fact that those machine a really small
this would be a better choice
http://www.arceurotrade.co.uk/Catalo...CNC-Hobby-Mill
Old 10-09-2008, 10:41 AM
Job Job is offline
Thanks,
By milling more slowly and doing more "rotations" would that go through with decent accuracy?
Since I don't really care about machining time (but my wife will care about the size of the engine in the living room ).
How much do these machines retail in America?
Est-ce que tu es Quebecois ou Canadien francophone ?
Old 10-09-2008, 10:44 AM
rowbare is on a distinguished road
If your search takes you towards a Tormach, here is a link to a recent thread started by a UK user where they discuss shipping etc: Tormach Mills in the UK?
Old 10-09-2008, 10:47 AM
ataxy's Avatar
oui je suis quebecois
i do not have price of the kx3 in front of me but i just bought, and i am waiting for it to arrive, a x4+ with coolant, 4th axis and a tormach tts and with the shipping and taxes it came down to 7900$ i did not need to buy tooling much since i allready have a BF20 clone and i got alot of end mill allready but i would say that if i had none i would have to spend at least 1k to 1.5k more
Old 10-09-2008, 10:52 AM
Job Job is offline
Thanks,
Tormach looks great too, but with taxes and shipping, it would cost twice the kx3 (as USD is now rather strong!).
(je suis un Francais expatrie qui bosse pour une banque cadanienne )
  #11   Ban this user!
Old 10-09-2008, 10:59 AM
ataxy's Avatar
yes i am quite happy that i bought mine while my cad was closer to the usd your other option to the kx3 would be like me the x4+ wich you can get from
http://www.syil.co.uk/
pour quelle banque travaille tu?
  #12   Ban this user!
Old 10-09-2008, 11:45 AM
Job Job is offline
Je te mél .
By the way how capable are little machines like an X2.
I had also found the link of this machine :
http://www.centroidcnc.com/oems/mho/mho_index.htm
Anybody has tested it or know the price?
Help choosing small CNC router PEZSEZ Canadian Club House 8 11-20-2009 12:11 PM
Choosing a vise for a small mill DonF Benchtop Machines 7 01-14-2008 10:20 PM
Choosing my next CNC Mill apeman88 General Metal Working Machines 2 11-09-2007 04:59 PM
Choosing the basis for a small CNC mill Pretorien Benchtop Machines 4 01-26-2007 12:35 PM
Need some help choosing a CNC mill Darkassaliant General Metal Working Machines 2 07-27-2006 07:35 PM
