Old 10-01-2008, 04:05 AM
tomshep is on a distinguished road
Advice needed.
The time has come to buy a small mill suitable for watchmaking. Concentricity and accuracy of placement are the crucial factors, I expect and CNC may not yet be necessary. Has anybody experience of a machine known here as a Chester Champion BV20 which seems to be the same as the German Optimum machine (And is almost certainly Chinese...). Would this be suitable?
Old 10-01-2008, 04:21 AM
jalessi's Avatar
jalessi is on a distinguished road
Smile
Tom,
Take a look at a American made Taig.
http://www.taigtools.com/mmill.html
Welcome to the Zone!
Old 10-01-2008, 04:08 PM
philbur is on a distinguished road
2200 rpm is to slow for your application.
These people make machines specifically for horological work. Not cheap though, but then again not made in China.
http://www.cowells.com/
Do you have a watchmakers lathe.
Phil
Old 10-01-2008, 05:37 PM
Stepper Monkey is on a distinguished road
I've never seen a Chinese benchtop mill I would even regard as close to the necessary quality and function of a Taig for fine detail work like watchmaking, and even the Taig is definitely NOT something I'd want to do horological work with unless I had no other choice.
I would suggest either (1) dedicated watchmakers equipment, (2) possibly looking into higher-end Minitech, Model Master, or Roland mills, likely in that order, or (3) assembling something yourself from semiconductor and optical industry surplus (not as hard as you'd think, for your needs its actually quite simple).
Old 10-01-2008, 05:59 PM
fretsman's Avatar
fretsman is on a distinguished road
The cowells machines look pretty sharp-
Dave->..
http://tinyurl.com/DLAManufacturing
advice needed / to buy or not??? teamjnz General Metal Working Machines 13 08-27-2008 09:48 AM
Cutting advice needed ninauk Laser Engraving & Cutting Machines 5 11-26-2006 06:33 PM
Overall setup advice needed dracin General Metalwork Discussion 0 08-21-2005 06:59 PM
advice needed trubleshtr General Electronics Discussion 32 04-21-2005 09:48 PM
Little advice needed STUG DIY-CNC Router Table Machines 1 01-25-2005 08:11 PM
