Old 09-27-2008, 06:07 PM
MrArmyAnt is on a distinguished road
Is this mill ok?
I'm just starting out, will be milling smaller car parts and pulleys. Eventual CNC conversion. any opinions?
http://oklahomacity.craigslist.org/tls/856421084.html
Old 09-27-2008, 06:42 PM
hoss2006's Avatar
hoss2006 is on a distinguished road
The Lathe would make a nice candidate but the mill which is basically a drill press wouldn't be worth the effort.
Would want to know more specs such as spindle bore and swings before I spent 650 for it.
Might be similar to a 9x20 lathe you can get new for $800ish.
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
Old 09-27-2008, 09:40 PM
ZipSnipe is on a distinguished road
For someone just starting out its not a bad deal, especially if your tight on room. The lathe part should work fine , like Hoss said the mill is probably not too great but for starters it might work out for ya just fine. $650 ? I'd probably go in with $550 or $600. Good luck
Old 09-28-2008, 01:31 AM
DonFrambach is on a distinguished road
The motor is 220 v. For me, that would be a problem. I'd pass. Have you considered Taig?
Old 09-28-2008, 05:33 AM
Torsten's Avatar
Torsten is on a distinguished road
Similar New Machines can be had for around $700.-
Looks like a older Machine, resonable Lathe but very limited Mill.
I would not pay more then $200.-, this will cover you for some minor repairs, new motor etc.
Good Luck
Old 09-28-2008, 03:05 PM
sansbury is on a distinguished road
$200 sounds about right. 220V will rule out a lot of buyers. Does it have a gearbox for threading? I didn't see one and some of these 3-in-1s don't. I didn't think I'd do a lot of threading until I realized how useful it could be. The mill part looks pretty weak. Better than a drill press but I wouldn't expect much of it. Also the older Chinese machines can be lower quality than the newer ones and slightly harder to get parts for.
I'd look at this--potentially--as a backup/training wheels machine but nothing more. If you really only need lathe work save your money and buy a 7x10 or 9x20 Sieg lathe for well under or a bit over the listing price. At $200 it might be worth the trouble of picking it up and moving it.
Old 09-28-2008, 10:44 PM
LUCKY13 is on a distinguished road
No its not OK, unless you already have other machines and are looking for a prodject. For a first lathe I would pass it up unless its very cheap ( $100.00 to $150.00) and only then if your welling to spend money and time on it. Then you will need other machines to be able to work on this one because your not going to find parts for it. If it was cheaper it would be great to use the parts out of it for prodjects.
Jess
Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head fignoggle Benchtop Machines 18 05-12-2009 12:11 AM
Coming Down to the Taig Micro Mill or Grizzly Mini Mill. SpeedsCustom Taig Mills & Lathes 15 01-23-2009 12:14 AM
RFQ - milling work on 1/4" wide tool steel - may need azis mill or right-angle mill pendentive Employment Opportunity 7 01-21-2007 08:56 PM
