Results 1 to 6 of 6
Thread: Rong Fu Good enough for Production Work
    Sep 2007
    I have a Rong Fu RF-45 square column mill. I am looking at doing production work in aluminum and various plastics. My question is this mill capable of producing parts consistently and with precision?
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Smile
    I am assuming you are talking about a stock RF-45 and its not a cnc conversion.
    If you install DRO'S on all axis it should be fine as long as you dont exceed depth of cut limits etc...
    Jeff...
    Sep 2007
    My RF-45 will not be CNC, I have added a 3 Axis DRO and I plan to add a tach soon. I changed the motor over and I am using a DC motor controller. I plan on adding a "One shot lube system", a power drawbar and X-axis power feed. The only other items I might due is fill the column and base with epoxy (supposed to eliminate vibrations) and add ballscrews. The ballscrews would be later on and maybe not until I CNC the machine. I just wasn't sure if this machine was capable of handling 40 hours a week of machining for the next year or two without wearing out.
    Feb 2007
    U.S.A.
    Smile Gromax Auto Lubricant Pump
    If you get a Auto Lube Pump with a built in timer it will automatically oil your machine.
    The oil pump time is adjustable, wire it to turn on with your mill.
    The RF-45 should last a very long time
    See attached links
    http://tinyurl.com/4wdvpx
    http://tinyurl.com/4o3ykl
    Jeff...
    Registered SpeedsCustom's Avatar
    Sep 2006
    Can you post pictures of your mill?
    -Jason
    Sep 2007
    I'll post a couple of pics this week when I get a free moment.
    1. What casting method should I use- production work
      By mattsam in forum Casting Metals
      Last Post: 06-25-2008, 09:31 AM
    2. any good for work stone
      By marktill in forum Solidworks
      Last Post: 03-31-2008, 06:35 PM
    3. What to charge for Production Work?
      By abelloise in forum WoodWorking
      Last Post: 09-19-2007, 09:55 AM
    4. Looking for all Mill work(prototype,production)
      By cutting edge in forum Employment Opportunity
      Last Post: 02-15-2006, 11:02 PM
    5. Here's some good information on making work holddown vacuum pods
      By buscht in forum DIY CNC Router Table Machines
      Last Post: 01-31-2005, 01:22 PM
