Old 09-21-2008, 04:12 PM
isaac338 is on a distinguished road
simple X2 handwheel dial mod
I got pretty frustrated with the dials on the handwheels rotating around on their own with the vibration of the machine and ruining my measurements, so I took the wheel apart to try and bend the spring slightly more round to give it some more tension, and of course I dropped it and it disappeared into the depths of the shop floor.
This was my solution: drilled a hole right by the 15 mark, tapped it M4x0.7, and threaded in a small socket head cap screw. The knurls on the head of the screw make it easy to tighten and loosen by hand, and it's a positive lock so that dial ain't going anywhere. I find having it by the 15 mark is the perfect position to get your hands in when the dial is set to 0.
Sorry for the crappy picture - all I have is a camera phone.
You could probably make it better by making something that would be fastened to the non-moving part of the wheel so the clamp screw would always be in the same place - it'd save fiddling with unscrewing it when the 15 mark is right at the bottom. But for the 15 minutes this took I think it's good.
Old 09-22-2008, 09:42 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi isaac338. Welcome to the Zone!
That's a nice emergency fix. Well done! Photo is not too shabby for a cell phone.
CR.
Old 09-22-2008, 12:22 PM
The Blight's Avatar
The Blight is on a distinguished road
Nice fix, and nice picture of your foot I bet your cellphone can take some nice pictures if you can get it to focus on what your taking a picture of.
Old 09-22-2008, 12:46 PM
cota is on a distinguished road
CR.
In case you didn't notice, he's been a member far longer than you, just not
as full of blah, blah, blah.
Welcome to the Zone by the way!
Old 09-23-2008, 09:41 AM
Yeah, I wear slippers in the shop. Sue me. haha.
I just need a real damn camera.
Old 09-23-2008, 12:19 PM
The Blight's Avatar
Haha don't need to sue you, just throw some brass chips on your foot, and your screwed I once had slippers on in the shop too, but my teacher told me to go change :P
The picture looks good enough, and I can see that it takes clear pictures once it has found something to focus on.
Need Help!- Handwheel command and MPG precourt CamSoft Products 5 03-24-2008 11:14 AM
Tree Handwheel dougwr Tree 0 03-10-2008 04:03 PM
Heidenhain Hr-410 handwheel khbash General Electronics Discussion 0 08-04-2007 07:42 AM
tm-1 handwheel removal? superrat Haas Mills 6 11-10-2006 10:52 AM
Handwheel Installation plateroomred CamSoft Products 3 05-24-2005 05:28 PM
