Old 09-19-2008, 08:39 PM
X2cnc is on a distinguished road
X2 power drawbar
I used a low-mounted air cylinder on the left side and a rocker arm for my X2 drawbar. This is Hoss's engineering; ratios, air cylinder, Belleville springs, etc. All I did was rearrange some of the parts.
The top rocker has a ball bearing because I had some on hand, and I figured it would make a nice (non)wear surface. The top rocker is split and clamps to the rocker shaft, which is welded to the long lower arm. You have to unclamp the top rocker and then slide the shaft out the right to disassemble.
The side plates are .090 steel. The bronze bushings came from Lowe's, and are a thumb press fit into some tubing I had on hand.
One change from Hoss's design is the air cylinder, mount, which I don't have a picture of yet. I made a bracket to hold it by the nose, running back to a bronze bushed pivot, so the cylinder can swing as it moves the lever. Hoss's design uses a slot in the lever, which apparently works just fine.
I had to make some spacers for the side pieces so I could change the belt. The clevis had to be shortened to make everything line up right.
I'll post some better pictures later.
ID:	66661   Click image for larger version
ID:	66662   Click image for larger version
ID:	66663   Click image for larger version
ID:	66665   Click image for larger version
ID:	66666   Click image for larger version
ID:	66667   Click image for larger version
ID:	66669   Click image for larger version
ID:	66670   Click image for larger version
ID:	66671   Click image for larger version
Tags
x2 power drawbar
Anyone mounted a power drawbar to their X4? MadMax Syil Products 1 04-02-2008 02:36 AM
Homemade power drawbar bigvinney General Metal Working Machines 18 02-19-2007 12:32 AM
Which Kurt Power drawbar? acerocket Bridgeport and Hardinge Mills 0 09-14-2006 12:02 PM
power drawbar fourperf Bridgeport and Hardinge Mills 3 03-21-2006 09:28 PM
Power DrawBar Mechanism vmax549 Bridgeport and Hardinge Mills 6 11-18-2005 06:10 PM
