Old 09-19-2008, 01:39 PM
Fixittt is on a distinguished road
Gecko G540 on a minitech minimill 2
After setting up the G540 yesterday I was playing with the motor tuning......
Here is the setup as it sits.
Minitech Minimill2 1/2-10 tpi precision acme lead screws, xylotex 269 OZ steppers (2.8A) G540 driver and a 24V power supply.
I had the power supply from my first Xylotex kit that took a swan dive on me a year ago. Also for the resistors, I needed 2.8K but the local rat shack only had 2.2K So I am severely under powered by the limit resistors and the low voltage PSU.
Here is a short video I took of it running a test toolpath.
Old 09-19-2008, 02:16 PM
Regnar's Avatar
Regnar is on a distinguished road
SO what do you think? Can you notice a difference now with it being underpowered or is it just the same? Im inquiring because it has been on my list of things to pick up. Thanks
Old 09-19-2008, 02:19 PM
i notice it in torque as with a little bit of pressure, I can stall the motors. But I am only machining wax. With a 48V PSU and the right resistors, I cant imagine what this sucker will do. As it is, I can go to 45,000 kernel speed and top out the motors in motor tuning. which is just under 3450 mm per minute and it will Rapid all day long. The video was run at 2000 MM per minute. My xylotex/maxnc combo will run reliable at 700 mm per min. But that is apples to oranges
Old 09-22-2008, 07:43 PM
while the jogging looks cool, it all boils down to if the part comes out right, and I am saddened to say that I will re returning the g540. Man I had such high hopes!
Old 09-22-2008, 08:24 PM
Regnar's Avatar
So your saying your xylotex is better than the 540?
Old 09-22-2008, 08:33 PM
I am going to say that the xylotex that I have is 1000% better then the g540 that I have. Why? because while the g540 tosses the machine around fast and smooth. When it comes down to making a part. I cannot get the g540 to cut a simple design in wax. it comes out ugly wrong!!!!!!! If it cannot faithfully produce a model for me, then its useless. I put the xylotex kit from the maxnc on the minitech mill and it cuts fine.
Old 09-22-2008, 10:10 PM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Thats really odd, I have yet to set my 540 on the mill. I'm sure some of you remember about 4 months ago my whole Xylotex problems???? I was skipping steps, couldn't even cut a piece at 1 IPM. it was horrible, went back to my "No name" drivers and cut like butter.
-Jason
Old 09-23-2008, 10:46 AM
Harryman is on a distinguished road
Weird, think it can't handle complex 3D moves?
www.harryhamilldesigns.com
CAD sculpting and services
Old 09-23-2008, 02:16 PM
im still testing......
Old 09-23-2008, 02:53 PM
There was a Recall on my Gen 2, new one came in the mail today. But it doesn't constitute to your problem.
-Jason
  #11   Ban this user!
Old 09-24-2008, 08:58 AM
for those of you who haven't seen my thread in the gecko section, My stubbornness paid off, I was finally able to get a descent wax cut with the g540. I figured I would spend one more day on it before sending it back.
Come to find out, that when I enabled the sherline 1/2 pulsing mode in mach 3 all my problems went away and I was able to cut my models just fine.
Speed, I dont know if this will effect you and your EMC2 setup but keep it in mind buddy.
I was even able to cut a model at 2500 mm`s per minute and while the wax had a few minor flaws due to the speed. I was greatly impressed.
  #12   Ban this user!
Old 09-24-2008, 07:20 PM
Astroguy is on a distinguished road
YouTube - Minitech minimill 2 gecko G540 test run
Here are the resistors you need you get 100 of them for $1.00
http://cgi.ebay.com/ws/eBayISAPI.dll...m=170040546439
Need Help!- Retrofit with G540 possible? mickenordin Gecko Drives 6 01-10-2011 01:45 AM
g540 Scooby Doo Gecko Drives 62 05-17-2009 02:44 PM
New stepper for Gecko G540 Kelinginc Product Announcements & Manufacturer News 7 01-29-2009 11:18 AM
Setting up the G540 boxwood Gecko Drives 4 09-15-2008 01:44 PM
Minitech Minimill port Pinout? rustyolddo Benchtop Machines 1 12-11-2007 07:56 PM
