  #25   Ban this user!
Old 06-06-2009, 07:16 PM
LegendCJS is on a distinguished road
I think I know what is going on. The computer you are using to control the gecko 540 is probably newer and as a result your parallel port can't source enough current to drive the optos on the G540 with two microseconds. On modern computer parallel ports only 40 us of pulse width is long enough to fire optos reliably with the low current modern parallel ports have. Without the Sherline 1/2 stepping mode Mach3 seems limited to 15us pulses at maximum.
Old 06-07-2009, 11:31 AM
KTP KTP is offline
Gold Member
KTP is on a distinguished road
Just add a buffer chip between the parallel port and the G540, then run whatever pulse width you want and the buffer chip will drive the optos in the G540 with plenty of current.
Need Help!- Retrofit with G540 possible? mickenordin Gecko Drives 6 01-10-2011 12:45 AM
g540 Scooby Doo Gecko Drives 62 05-17-2009 01:44 PM
New stepper for Gecko G540 Kelinginc Product Announcements & Manufacturer News 7 01-29-2009 10:18 AM
Setting up the G540 boxwood Gecko Drives 4 09-15-2008 12:44 PM
Minitech Minimill port Pinout? rustyolddo Benchtop Machines 1 12-11-2007 06:56 PM
