| spindle hole, collet and chuck maintenance Hi, I have installed my new Quantum BF16 vertical mill and used it for a while. Then I noticed that the end mill is exhibiting a slight wobble. I removed the collet chuck (2MT) and used a dial indicator to check the inside hole of the spindle. It was nearly perfect. Then I checked the outside of the collet chuck, it has visible wobble. Then I checked the outside of the end mill and it had more wobble. I did some research on this issue and have read that the collet chuck taper and the spindle hole must be very clean. How must this cleaning be done? When I bought the collet chuck and a few collets, they were all soaked in oil. I thoroughly removed this oil using a paper towel and paint thinner. Should I use the collet chuck and the collets "dry" or should they all be used and stored with a thin film of oil on them? Any tips welcome ... |
| a piece of wood that as the same same exterior conical shape as the taper can do a nice job of cleaning the taper, but also a good shot of a lint free rag can do a good job. storing them with a thin coat of oil is a good thing in my opinion but the should be wiped dry when you insert them in the taper with a lint free cloth.
__________________ The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne |
| Kress Collet/Chuck Problem | djh82uk | Benchtop Machines | 9 | 10-08-2011 05:15 AM |
| Which collets to use with BT40 Collet Chuck | JMFabrications | General Metalwork Discussion | 3 | 05-18-2009 09:21 PM |
| Need Help!- collet chuck onto rotary table | ptxman | Work Fixtures and Hold-Down Solutions | 4 | 09-15-2008 01:35 PM |
| Air collet chuck for a c3? | gazmalman | Mini Lathe | 0 | 06-15-2008 07:23 PM |
| Which collet chuck? | Al_The_Man | General Metal Working Machines | 3 | 06-27-2004 02:11 AM |
