| Cuuting cricles with mini mill Is there an attachment for the X-2 manual mill that will allow cutting circles in aluminum? I was thinking something that could bolt to the table with the aluminum in the horizontal position, it would need some kind of geared handle to turn the piece to cut the circles. |
| what size of hole if this is what you are trying to accomplish or is it exterior diameter you are trying to do
__________________ The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne |
| Inside and outside circles. About 4 inches in circumference. |
| aside from a rotary table you will have a hard time making diameter this size on a manual mill
You sure about circumference? Thats about 1.5" diameter? in which case a boring head or Hoss'e example rotary table will do it. If its 4" diameter you'll need either a 6" rotary table or a bigger than X2 CNC mill |
Yep......4" in circumference is what I am after, 4" in diameter is too big for the X-2? |
| You can cut stock much bigger than the rotary table, you just have to put a couple mounting holes in it. This is a 6 in. dia. part on my 4 inch rotary table. There's enough clearance between the column and spindle to mill a 12 in. dia. if you wanted. Hoss
__________________ http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com |
| Even larger actually if it's just milling toward the edge like this part. The center will be offset in the X giving extra column clearance.
#10
| Hey! I recognize that part! Have you ever needed to swivel the head? I figure if you'd found a use for it, the Freak would have a stepper there and you'd have a 5-axis machine! |
#11
![]() Hoss
| Mini lathe and mini mill spindle? | ZipSnipe | General Metal Working Machines | 3 | 10-15-2010 09:13 AM |
| Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head | fignoggle | Benchtop Machines | 18 | 05-12-2009 12:11 AM |
| Coming Down to the Taig Micro Mill or Grizzly Mini Mill. | SpeedsCustom | Taig Mills & Lathes | 15 | 01-23-2009 12:14 AM |
| ToolRoom Mill/Mini Mill | StampCraft | Haas Mills | 14 | 01-07-2008 01:02 AM |
| X2 Mini Mill & Mini Lathe - Cummins Tools | ccsparky | Benchtop Machines | 0 | 12-19-2007 08:54 AM |
