Old 09-11-2008, 10:47 AM
circlecn is on a distinguished road
limit switches -proximity sensor vs optical
Hi, I am installing limit switches on an IH mill. I thought I would address this question to a broader audience in this forum.
I hope it is appropriate.
Which switch will give the most accuracy -- proximity sensor or optical. I have a Proximity sensor, 12 mm diameter, 10-30 VDC, 3-wire, NPN from Automation Direct in mind. Or a homemade optical setup (fully enclosed). I have used these proximity switches with Mach3 with success but in an application that doesn't require the precision I would like to get with my cnc conversion of the IH mill.
Thanks for any help -- opinions
Kent
Old 09-11-2008, 11:10 AM
Al_The_Man's Avatar
If the inductive or optical device does not have any shaping circuitry for e.g. a Schmidt trigger circuitry, the output will be a gradually increasing slope, decreasing slowly as the device is passed.
So if using discrete slot sensor or similar, this can be the result.
Most all-in-one Hall effect devices, and some optical devices have a squaring circuit in them.
Obviously the signal conditioning type will give you more consistent results.
It is something to be aware of.
optical limit switches woffler Benchtop Machines 7 12-17-2007 05:01 PM
PROXIMITY SWITCHES CHANDRU General Electronics Discussion 1 12-12-2007 07:33 AM
optical limit switches phantomcow2 DIY-CNC Router Table Machines 4 03-05-2006 06:48 AM
Optical sensor... aghobby DIY-CNC Router Table Machines 1 09-08-2004 11:17 AM
Optical Limit/Home/Reference Switches redbaron DIY-CNC Router Table Machines 5 02-06-2004 07:47 PM
