Results 1 to 3 of 3
Thread: Cutting parameters with X2 advice needed
    Registered SScnc's Avatar
    Jun 2008
    What would some of you experts advise as proper cutting parameters such as spindle speed, cutting depth, feedrate, ETC. using a Griz X2 and a 1/4" endmill on the .DXF below ?
    It's 1/4" thick mild steel.
    THX.
    Attached Thumbnails Attached Thumbnails Cutting parameters with X2 advice needed-caster_mounting_plates.jpg
    Attached Files Attached Files
    Gold Member hoss2006's Avatar
    Apr 2006
    Use about 1500 RPM @ 6-15 IPM with .025 DOC should be OK (it's up to you)
    maybe .010 for a finish pass and some kind of coolant/oil.
    This Calculator is a big help, do the RPM 1st, then the Feed Rate 2nd.
    Surface Speed Ft./Min. figures are in the chart below.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jun 2008
    Thanks for your advice Hoss, I went with 4 ipm (just cautious while still learning) and .025 DOC, ~1500 RPM and that worked very good.
    And thanks also for the link to Online Metal Supply in your ATC thread, I had been looking for a hunk of 6061-T6 at a good price for milling a mold for my injection machine I built recently and they had the perfect size at a fantastic price.
    Steve
  1. Need Help!- cutting parameters for natural peek
    By fsa in forum General Material Machining Solutions
    Last Post: 07-04-2008, 12:30 PM
  2. Need Help!- QT10 chuck barrier data..and parameters needed (YESTERDAY!..help)
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-05-2008, 04:16 PM
  3. T1 parameters NEEDED!
    Last Post: 11-12-2007, 10:47 AM
  4. Cutting advice needed
    By ninauk in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 11-26-2006, 06:33 PM
  5. cutting parameters
    By captahab in forum CNC Wire Foam Cutter Machines
    Last Post: 01-15-2006, 11:11 PM
