Hello! wich parts do I need to buy in order to use a mini lathe chuck on the X2 spindle? I'm looking at the LMS website but there are so many parts that I'm no confident wich are the right ones ![]() Also I sent an email to lms but got no reply thanks |
| Do you want to attach it temporarily or permanently? The X2 spindle housing is the same casting and uses the same bearings as the 7x mini-lathes. You could press out the mill spindle and mount a mini-lathe spindle. The mini-lathe spindle has a 3MT taper so you might be able to still use that for milling with a drawbar? Just a thought. For more temporary... you could also buy a blank R8 arbor and machine it so you could mount a face plate. Then you could bolt the chuck onto that, and it would be temporary. |
__________________ Lee |
| It is going to be a permanent modification. In fact I'm disassembling my homemade mill (wich have a X2 head) to build a micro lathe. My cnc mill works OK for wood and aluminium, but I'm using it only 3 hours a week while I need a lot more of lathe work. So I intend to build the lathe using the most of the mill parts I can. So good the mill head uses the same bearings as the mini lathe Thankyou very much guys. I will buy that kit from ebey and hopefully start building my new machine soon |
| Which lathe chuck? | CNC Pro | General Metalwork Discussion | 13 | 08-25-2008 08:57 AM |
| How can I mount a chuck in my mill spindle? | cnczoner | General Metalwork Discussion | 6 | 03-09-2008 07:34 PM |
| Spindle Chuck Questions | SPEEDRE | DIY-CNC Router Table Machines | 5 | 01-19-2008 12:28 AM |
| new lathe chuck | skyway0018746 | Metal Working Tooling | 10 | 01-01-2008 12:36 PM |
| How do I remove a kwik chuck/spindle | Andyh | Bridgeport and Hardinge Mills | 1 | 08-14-2005 12:28 PM |
