Old 08-09-2008, 10:45 AM
Jay C is on a distinguished road
My new High Speed Spindle
The good news: I got my Wolfgang Engineering spindle (he no longer sells them on eBay).
The bad news: I go to start making a mount for it and my Z-axis is dead on my HobbyCNC Pro. I test the Z using the Y-axis driver and it works.
The good news: I have a Gecko 540 on order.
Anyway, here is the spindle and the mount I'm planning. The spindle body if .75" in diameter. The mount will screw to the side of the X2 head. Looking for input since I have time on my hands.
Thanks,
Jay
ID:	64515   Click image for larger version
Old 08-09-2008, 02:52 PM
philbur is on a distinguished road
Don't know what mill you have but if you make the bracket so that it clamps around the existing spindle nose you don't have to drill and tap the head.
Phil
Thanks,
Jay
Old 08-09-2008, 03:26 PM
I thought about that ... but then I'd need to modify the spindle lock that came with my belt conversion.
As for my mill, it's a X2 Mini Mill.
Old 08-09-2008, 05:36 PM
Well, I got some help with my driver board issue so I was able to cut out a prototype in plastic. It's only .25" whereas the real one will be .5" but it works
If anyone has some photos of a spindle mount that mounts to the mini mill spindle or even a Bridgeport one ... I'd like to see them please
Jay
Old 08-10-2008, 11:40 AM
Fixittt is on a distinguished road
well I dont have a minimill X series..... but I have a maxbc machine using one of those spindles and I have to say, for the price, its one damn good spindle. Not alot of horsepower granted, but its not designed to chew up hard material. I use mine for wax. Cool thing about it, is that you can keep your existing spindle in the machine and mount it off to one side of the head if you so desire.
Old 08-10-2008, 12:56 PM
lovebugjunkie's Avatar
Gold Member
lovebugjunkie is on a distinguished road
Jay
I had a little different experience with the spindle. I picked up one late last year. It was the one he listed with double bearings on the collet end. I used it for cutting a lithopane and a few engravings in wood. Bearings went out on it with less than 10 hours of use. You may want to only use it for engraving.
Sent him email asking if it can be re-built. Never received a response.
Old 08-10-2008, 01:17 PM
Originally Posted by lovebugjunkie View Post
Jay
This is his top of the line triple bearing TB-350S. After talking to fixitt and seeing videos on youtube of this model (fixitt has issues with the double bearing model too) I settled on this one.
I think I'm going to make (or have one made by my new machinist buddies at FedEx) a mount that is a cross between the one made and the one LMS sells from KDN.
I'll post the CAD drawing when I'm done but right now, I'm debating on should I go 1" thick like Hoss did, or .75" thick like KDN? I'll see what scrap I can find I suppose and design it for 1"
Thanks for the feedback guys.
Jay
Old 08-10-2008, 01:30 PM
Gold Member
Yep, that's the one, I think we are talking about the same one, two ceramic bearings on the head and on bearing at on the pulley end. I bought that one as he mentioned it can route Aluminum, brass and mild steel. I thought it would work great as I was not going to cut anything that hard.
Well I always assumed he sent me the 350S but looking at yours and the one he has listed on ebay I notice that the one you have and one still listed on ebay has a smooth polished finish, mine had a matte finish.
I do know I ordered the 350s as I had to explain to the "banker" why I did not want the cheaper model.
Old 08-10-2008, 01:42 PM
its really hard to have QC over bearings, and I understand that...... mine went out and I got it replaced....... No biggy, My new one is going strong......... I have been thru a few of the little spindle motors. Chewing the helk out of some wax I tell ya! Compared to the runout of the stock spindle I had, and the replacement costs of the dayton motor it used. This spindle is a god send,
Old 08-10-2008, 01:58 PM
Gold Member
I agree with you Fixittt, bearing going bad before it's time is no big deal to me. What bothered me more than the spindle going bad is not receiving a response to the email I sent.
The good news is I picked up a Porter Cable and also the collet set from here:
http://www.precisebits.com/products/...llets_nuts.asp
and very happy with it.
I do miss the wolfgange, it was quiet and very precise while it worked.
  #11   Ban this user!
Old 08-10-2008, 06:27 PM
Yes Richard was a bit sparse in returning emails but he forewarned me that would be the case. I can contact him on your behalf if you like ... he treated me honest and fair and I'm sure he would extend you the same courtesy.
On another note, here is what I drew up. Comments?
Note: I used the .dwg file of the Mini Mill I downloaded from the Grizzly Yahoo Group. HUGE THANKS to Eric Na the man that provided it
  #12   Ban this user!
Old 08-11-2008, 12:56 AM
This one shows the spindle "attachment". I have several plans for this mount plate. Including:
  • A tachometer sensor
  • A dust collection attachment
  • Possibly a mister or a drip coolant attachment
  • A webcam attachment
  • A LED ring light
Feedback is welcomed.
Add DIY high speed spindle? bseibenick General Metal Working Machines 11 12-08-2009 09:35 AM
VFD help for high speed spindle juzwuz Phase Converters and VFD 4 03-21-2009 08:27 AM
High speed spindle yngndrw General Metalwork Discussion 9 06-26-2008 03:19 PM
High speed spindle... how high? jonesja2 General Metal Working Machines 0 06-04-2007 07:18 PM
High Speed Spindle 10,000 to 40,000 rpm whelen Mechanical Calculations/Engineering Design 5 09-05-2005 08:42 AM
