Old 08-05-2008, 12:41 PM
tikka308 is on a distinguished road
Buying Expensive Air Compressor - Any other rec's?
I need a relatively compact, QUIET air compressor for use in a residential apartment building. After doing a fair amount of research, the best (and, so far, only) option are compressors made by Silent Aire. I'm about to purchase their Sil-Air 50-15 which is a 1/2 HP, 4-gallon model. It uses a piston-motor similar to your refrigerator and produces ~40db (far lower than normal conversation level). I will be using the compressor to blow chips out of my cutting path as well as to run either a Fogbuster or a Trico MD-1200 (uncertain of which one yet).
This compressor is going to cost me ~$900, so before purchasing, I just wanted to ask if anyone else had any recommendations!
Link: http://tinyurl.com/6hfq2o
Link 2: http://tinyurl.com/6dytmj
Thanks.
Tormach PCNC 1100, SprutCAM, Alibre CAD
Old 08-05-2008, 01:09 PM
bilinghm is on a distinguished road
This might be a good deal for you:
http://cgi.ebay.com/SIL-AIR-Silent-A...6.c0.m14.l1318
Old 08-05-2008, 01:41 PM
Or this: 69 Db
http://www.amazon.com/Senco-PC1010-C.../dp/B0000AQK78
Old 08-05-2008, 02:20 PM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
The on from Ebay looks badass!
-Jason
Old 08-05-2008, 03:01 PM
jpgdesigns is on a distinguished road
Check your CFM rating... most times small compressors can't keep up with your demand...
Old 08-05-2008, 06:31 PM
bilinghm - many thanks! Great spot on that eBay one.. I wish it were the 4 gallon instead of the 1.5 - but it's still tempting.
That Senco unit also looks quite interesting; 69db is only slightly louder than talking-levels, if i'm not mistaken... and a heck of a lot cheaper!
Old 08-07-2008, 11:14 PM
pzzamakr1980 is on a distinguished road
get a small enclosure and run flood. It will cost you far less money and be extremely quiet
Old 08-07-2008, 11:16 PM
He has a really nice enclosure...
-Jason
Old 08-07-2008, 11:17 PM
Tikka, in a way, I kinda agree. I use this coolant that has no freaking odor and I run it daily, but sometimes it has not run for weeks. And it doesn't smell or get bacteria filled.
-Jason
Old 08-07-2008, 11:51 PM
Nevermind, I didnt notice who was writing this. But still, why dont you just run flood. Isnt the enclosure set up for it.
  #11   Ban this user!
Old 08-08-2008, 08:01 AM
The enclosure would definitely allow for flood. my concern stems from friends who have salt water reef fish tanks. over time, SOMETHING leaks. Yes, you can have an overflow "sump" that could capture everything, but I live in a highrise apartment building. Leaking "industrial machining coolant" would almost certainly get me evicted! I've also heard really good things about the fogbuster, so even though it costs more money, I don't think I'm compromising too much on the end result.
Do you guys still disagree?
  #12   Ban this user!
Old 08-08-2008, 08:09 AM
It's not that I disagree. If you just take the time too clean all the areas up and seal them up. You should be fine. Or especially if you ran the coolant on a relay/timer, or even full but small flow.
I just feel like a 400.00+ compressor is a nice tool too have, but you properly sealing up your enclosure and taking the pre-cautions. You could have a very nice leak proof system.
But I do understand your concern. But at the same time, you don't even need that large of a bin too hold it anyway. Most of the coolant is composed of water.
-Jason
Less expensive way to CNC an IH Mill ? OffshoreRacer Industrial Hobbies (Support forum) 6 09-19-2008 07:46 AM
Least Expensive CAM software for Solidworks Adamj12b Solidworks 2 12-10-2007 11:42 PM
Not Purchasing a CAD/CAM because you think it's too expensive?? Chad_Clark Dolphin CADCAM 5 04-08-2007 01:53 AM
Stop Buying Expensive EDM Pinch Rollers Jim Abbett Product Announcements & Manufacturer News 0 09-29-2004 03:51 PM
