Old 07-20-2008, 09:36 AM
chukkie is on a distinguished road
My $20.00 X2 belt drive
Got some timing pulleys and belts from sdp-si.com and modified for my X2 main drive and they work very well.
Super quiet
4250 RPM in high
Use stock gear change for high/low – I don’t hear the internal gears
Old 07-20-2008, 10:47 AM
cjdavis618 is on a distinguished road
That is a great idea. Others would greatly benefit in your work, could you post your part numbers?
Old 07-20-2008, 12:14 PM
sansbury is on a distinguished road
Chukkie,
Fantastic!
Hate to ask, but does your spindle get hot when you run this at top speed?
Old 07-26-2008, 01:37 PM
The spindle will get hot after running about 10 minutes or so at 4250 rpm's.
I will post the part numbers after I hunt them down.
Old 07-27-2008, 02:07 PM
Vogavt is on a distinguished road
I'm interested in this as well. I'd be happy to help with some sort of diagram if you'd share you're information.
Thanks in advance,
Vogavt
Old 07-27-2008, 05:41 PM
The parts I used
A 6R 3-031037
A 6A 3-20DF03708
A 6A 3-15DF03708
I used a lathe to modify these pulleys and used the stock gears for reference.
Also had to take a little off the inside of the top black housing – you can see in pic.
Also cut the flanges off the 15 grove pulley.
Old 07-28-2008, 09:35 AM
used the lathe to modify these pulleys and used the stock gears for reference.
I'm assuming you're talking about the outer diameters, but can you be more specific as to what modifications you made?
Are you talking about the shiny area between the gears?
Last question: How did you manage to get the correct belt tension between them? I've looked at mine and only see a limited amout of adjustment. Maybe I'm overlooking something obvious.
Thanks in advance,
Vogavt
Old 07-28-2008, 11:01 AM
Thanks in advance,
Vogavt
The drive pullet I bored out the hole, added a keyway, turned the sides till the flanges fell off, cut the hub off made a spacer and dished out one side of the pulley to center the pulley up.
The other pulley I did the same thing accept left the flanges on.
Yes the shiny area between the gears
On my X2 there was plenty of adjustment for the belt.
Also had to reverse the motor wires to get it to turn clockwise.
Old 07-28-2008, 12:10 PM
Hmmm... begs the question of why did you have to reverse the spindle direction. Mine runs CW anyway so I'm not sure how this mod makes that change.
Confused....
Old 07-28-2008, 02:18 PM
Confused....
When you have 2 gears one turns in one direction and the other turns in the opposite direction.
When you have 2 pulleys and a belt they both turn in the same direction.
  #11   Ban this user!
Old 07-28-2008, 02:24 PM
Didn't think about that. I'll have to pay closer attention when I finally get my C11 board in and try to wire this all up.
Thanks for clearing that up!
Vogavt
  #12   Ban this user!
Old 07-28-2008, 03:18 PM
The Blight's Avatar
The Blight is on a distinguished road
Don't know about your X2, but there were 2 gear transmissions in my mill. One is right under the black cover, the other is inside the head (high low gearing). So it still doesn't make sense. Unless you have just switched out the gears under the cover, and is still using the internal high low gears. I have a belt drive kit installed on my mill, and I have never had to revese the direction of the motor.
Took another good look at the picture you posted. You are still using the internal gears on your mill. That answers that question. I would like a pulley transmission like this if it bypassed the plastic gears inside the head. Don't know if there is enough space for that.
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 11 02-13-2012 02:12 AM
Belt Drive Jerry In Maine Commercial CNC Wood Routers 0 05-12-2008 11:50 AM
Need Sherline Belt & qestion on X2 Belt Drive? Oldboy Benchtop Machines 12 03-06-2008 12:42 AM
Belt Drive help bearwen Linear and Rotary Motion 5 10-31-2007 03:55 PM
Belt Drive? bearwen Linear and Rotary Motion 2 09-01-2007 08:07 AM
