Old 07-09-2008, 10:26 AM
bilinghm is on a distinguished road
Hot spindle drive motors: X mills, Tormach, IH
I ran my modified x2 mill at top speed (7,000 RPM) for 30 minutes to see how warm everything would get. The spindle was slightly warmed up, as was the cast iron head. The motor was very warm, but not hot. I could put my palm on it for 15 seconds without any discomfort.
I wonder how warm the motors become on other machines: Tormach, Industrial Hobbies, standard X3, X2, X1, treadmill motor conversions, and others.
Please post your results.
Old 07-09-2008, 07:38 PM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
My Taig motor gets hot but I run it for like 20 + Minutes taking decent cuts about 3mm deep. It's also in an enclosure.
-Jason
Old 07-09-2008, 07:43 PM
highspeedmazak is on a distinguished road
My tormach does great but I do run it in cold AC and have a spindle cooling system.
Old 07-09-2008, 10:01 PM
cob cob is offline
cob is on a distinguished road
I was going to asked that question.
is that bad when the motors get pretty warm or is that normal. or what can you do to cool them down
Old 07-09-2008, 10:09 PM
No matter what, the motor is going too get hot. But you can fan cool it, with a pc fan or try too water cool it.
-Jason
Old 07-10-2008, 02:53 AM
impact is on a distinguished road
Put a heatsink on it.
Does wonders.
Old 07-10-2008, 06:46 AM
cyclestart is on a distinguished road
My (very) uneducated response would be it's normal to get pretty warm to the touch.
Is the concern here reliability/service-life or performance/efficiency? My X2 motor gets warm but not warm enough to cause harm. Certainly not nearly as warm as most of the electrical items underneath the hood of a car. The alternator on my Neon sits very near the exhaust manifold but still held together for 160,000 km. The stock X2 motor does have a good size fan at the front end.
At what point does heat start reducing performance? Thinking of the car example, a hot starter is less efficient. Of course a starter isn't in continuous duty, so maybe a bad example.
Anyone who says "It only goes together one way" has no imagination.
Old 07-10-2008, 08:13 AM
How did you put a heatsink on? Please show us a photo.
Does wonders.
Old 07-10-2008, 10:18 AM
Regnar's Avatar
Regnar is on a distinguished road
Bill,
I have been thinking about the same thing lately now that the summer heat here in Florida has rolled in. I was thinking about doing something simular to this set up. http://www.harrisson.biz/fan.htm Only I was going to use a little bit bigger fan from here http://www.surpluscenter.com/item.as...tname=electric
With the Fusion kit we have about 3.5" from center of the motor the z axis mount. So in theory we should be able to fit a 7" fan with housing on the top of the motor. The disc on top of the x2 motor is 85mm or 3.34 inches and the fan blade size is 5.625 so I will have about a 1.125 overhand that would blow down the sides of the motor. I guess we will see if there is any benefit to all of it.
Old 07-11-2008, 10:07 AM
Regnar,
What if you put the fan at the end of a large diameter tube and the placed tube over the motor so that the airflow was pulled up the sides of the motor case and out the top? Might improve the cooling further.
Bill
Originally Posted by Regnar View Post
Bill,
  #11   Ban this user!
Old 07-11-2008, 10:15 AM
LeeWay's Avatar
LeeWay is on a distinguished road
My setup has a nice fan on the top. Neither the motor nor the spindle even get more than luke warm. Maybe 120 degrees F at most. This is running @ 6600 RPM on the spindle.
I have used two spindles on this, but only one at this speed. I would expect the same results from the other.
I will also say that the location of that fan really pulls any heat off and does so quickly. The motor itself runs @ 4000 RPM, so that 4" fan is moving some air.
Lee
  #12   Ban this user!
Old 07-11-2008, 04:47 PM
Regnar's Avatar
Leeway, Is it pushing or pulling air threw the motor? And do you remember how many CFM the fan pushed.
Tormach spindle bearings - assembly fault keen Tormach PCNC 102 08-11-2009 03:28 PM
Tormach coolant, spindle bearing, ring. highspeedmazak Tormach PCNC 13 02-11-2009 01:37 AM
brushless DC motors for spindle drive bilinghm Benchtop Machines 14 04-28-2008 04:16 PM
Using surplus servo motors as spindle drive Swede Servo Motors and Drives 11 03-16-2008 08:05 AM
can brushless drive drive brushed motors ? max_imum2000 Servo Motors and Drives 2 02-09-2006 07:35 AM
