Old 09-21-2004, 05:58 AM
kenlambert's Avatar
kenlambert is on a distinguished road
HF conversion
Finally got this machine to do something made my first cut at 3:30 am I borrowed the g code from Jeff Davis at home cnc it is the dinosore thingy .
ID:	3460   Click image for larger version
ID:	3461   Click image for larger version
ID:	3462   Click image for larger version
thanks Kenneth
web-www.lambertsrc.com
Learning CNC
Old 09-21-2004, 07:49 AM
thielert is on a distinguished road
Please tell us about the conversion.
How did you do the Z quill drive?
Did you use a plan set or your own design?
Stock lead screws or upgrades?
What size servos and what gear ratio?
Very nice looking job!
TT
Old 09-21-2004, 06:47 PM
kenlambert's Avatar
I got the plans set from Jeff Davis at Home CNC used gecko drives and Axxus board converted to ball screws and nuts on all three axis used the clifton $10.00 servos Mach 2 and Bob Cad Cam software the computer is a gateway 1.5 p4 80 gighd and is dedicated solely to run Mach 2 to control the machine. After I get the bugs out and running well I plan to ad a 4th axis Rotery Table it is an 8" and weighs a ton,all I need to do is figure out how to do all this programing between mach 2 and bob cad thats a lot of reading .THE Z AXIS
Name:	cnc machine 018.jpg‎
thanks Kenneth
Learning CNC
Old 09-21-2004, 07:56 PM
megavolt is on a distinguished road
awesome job!
Jeff's design seems like a good one. I love the concealed z-axis drive. I bought the cheap servo motors from him (he put encoders on) and used his Gecko box plans as well.
What did you think about his Z-Axis design? I've been toying with the idea of using a "rotating ballnut" design like this. Was it a hassle to build?
The sell off-the-shelf rotating nut ballscrew assemblies - with support bearings integrated into the nut. You just drop it in your assembly and clamp. They cost more than regular ballnuts however. I'm trying to decide if they're worth it.
John
Old 09-21-2004, 08:26 PM
kenlambert's Avatar
the z was the most time consuming i used the angle lock bearings and all i did use the us digital encoders and still have to wire the home and limit switches of course in the middleof the conversion i had another hartattack so that took a lot of time away from the project but it was easy enough for me and i am a beginer at the machinist thing
thanks Kenneth
Learning CNC
Old 10-05-2004, 04:13 PM
kenlambert's Avatar
well it works did my first multi part cut the machine is all done exept a little plexiglass and some home switches .these are spacers for mac 32 conversions for airplanes if any one would like to purchase a muffler let me know here are some pics of the machine and parts [IMG]http://[/IMG]
Name:	muffler mac 008.jpg‎
ID:	3556   Click image for larger version
Name:	muffler mac 004.jpg‎
ID:	3557   Click image for larger version
ID:	3558   Click image for larger version
thanks Kenneth
Learning CNC
Old 10-05-2004, 05:44 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Nice, very nice set-up you have their.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Need Advice for Clone Conversion lerman Bridgeport and Hardinge Mills 2 04-17-2006 01:48 PM
First Impressions for CNC mini mill conversion CNCadmin General Metal Working Machines 4 11-16-2004 08:37 PM
Newbie Looking for Advice (Sherline or HF Conversion) Deviant Benchtop Machines 21 09-26-2004 08:10 PM
Mini lathe conversion kdoney General Metal Working Machines 1 08-26-2004 10:21 PM
possible cnc conversion on homier mini mill WsW-WYATT Benchtop Machines 3 03-27-2004 07:24 AM
