Old 06-28-2008, 02:49 PM
isaac338 is on a distinguished road
key stuck in spindle shaft
I'm finally getting around to doing the R8 conversion on my Busy Bee mini mill. The thing's been sitting unused for quite a while, too much stuff happening lately.
In any case, I've got it all torn down and I'm ready to press the spindle out, but the key is stuck in the spindle. I've tried prying it slightly with a small screwdriver but I don't want to mangle the spindle and it won't move in any case. Anyone have any handy suggestions for non-destructive ways to get the key out? I know I could probably weld a small bead on it and it'd pop out but I'd like to save it, and knowing my unsteady hand I'd probably weld the damn thing to the spindle.... no good.
And there's definitely no way to press the spindle through that bearing with the key in place without destroying everything.
Thanks for any advice.
Old 06-28-2008, 03:24 PM
Al_The_Man's Avatar
I have used two methods, both similar, one, I drilled and tapped a hole the largest I could in the centre of the key, and then used an allen head screw with a slide hammer.
If this method failed, i.e. the thread stripped, I drilled the largest dia I could into the centre of the key, and then used a pin punch to drive one piece towards the other.
This is OK if you can get right angles onto the key.
Good luck.
Old 06-28-2008, 03:31 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
I have had good luck with heat (from a torch to expand the spindle slot) and vise grips for gripping the key.
CR.
Old 06-28-2008, 03:39 PM
Al_The_Man's Avatar
CR.
I have used that method also, what I usually do is give the key a squirt of WD40 to shock-shrink it momentarily, That OK if heating is not a problem.
Old 06-28-2008, 04:17 PM
Sorry, I should have searched first. It popped right out with a pair of side cutters. Now to work out pressing the new spindle in..
Another question - my mill has steel gears, but the replacements which came with the kit are plastic. Should I keep the steel gears (they appear to be identical), or install the plastic ones?
Old 06-28-2008, 04:25 PM
I would keep the Steel gears.
CR.
Old 06-29-2008, 06:27 AM
DMIOM is on a distinguished road
just a note - if you do this, be careful. I did exactly this when I was a student many years ago - and lost my eyebrows - the metal was hot enough to flash the WD40 !
Lagun 310 Stuck Spindle mcsf Knee Vertical Mills 5 06-07-2008 05:13 PM
Broken spindle motor shaft ;( Legion99999 Syil Products 4 12-22-2007 05:49 PM
Spindle stuck in neutral drmrby Haas Mills 2 11-12-2007 08:27 AM
Heat treatment for lathe spindle shaft mackeym General Metal Working Machines 10 10-15-2007 04:05 PM
Mini Mill Tool Stuck in Spindle esphobby Haas Mills 13 02-21-2006 09:29 PM
