Having finished my 3 axis X2 mill I thought I might add the 4th axis and use my 4" rotary table and I was wondering what size stepper to use. I do not think I need a 282 oz in as I have on my X and Y. Any thoughts on how small I can go. Many Thanks. Clive |
| It's all in the Transmisssion Ratio. I asume your X and Y axes use a leadscrew then figure out the the transmission ratio based on your screw pitch. Like one rotation advances the table this amount. Use the same Ratio with your Rotating Table, a 4" RT. may want to cut something at say a 5" diam. as a worst case example. This would be equal to a rollup of 5" x Pi. (Pi=3.1415) linear distance. Figure in your RT. gear ratio and make up the difference with Pulleys if needed. Good Luck |
| The only reason to use a bigger motor would be to overcome the friction of the worm drive. There's potentially a lot there, if you need to mesh it tight to overcome backlash. There's a big difference here between the best and the worst tables available. I have a Vertex 4" table and I run it off a 280 oz.in motor. No problems at all. I run my axes with 425 oz.in motors. |
| Newbie- Stepper motor and rotary table | ksor | Stepper Motors and Drives | 3 | 03-13-2008 06:59 AM |
| 8" Rotary Table Disassembly | ChrisJ | General Metalwork Discussion | 1 | 01-25-2008 01:08 AM |
| "Lathing" with a rotary table? | JMcDonald | Benchtop Machines | 19 | 10-13-2007 04:47 AM |
| little 4" rotary table won't stay put! | JFettig | Benchtop Machines | 3 | 02-20-2007 07:42 PM |
| Wholesale Tools 6" rotary table | CerveloRod | Benchtop Machines | 2 | 03-27-2005 10:11 AM |
