Hi, Just started milling on my newly cnc'd X2, I have a small piece that I created in GCAM (using EMC to drive the steppers). What I'm seeing is on the y dimension the part is .020" to small and the X is .010" to large. I have what I believe is very good repeatability, the cuts are all nice and lined up and I can run the program again with very similar results. I'm using the stock screws at this point and have taken account of the backlash in EMC, could my dimensional discrepancy be from a incorrect backlash setting? on the Y I'm trying to take .0105" off each side of an .375" wide piece of stock, it looks like the front cut is deeper than the back cut. and on the X its the opposite, left (start) is shallower, right is deeper any ideas? |
| First question, EMC? or EMC2? How are you driving the z-axis? Trying to have EMC2 control the Z-axis backlash can be very tricky on an X2 because it wants to pull the head down into the material when cutting (at least on a manual machine). I would first just try to measure the movement with a dial indicator in both directions (x and y) one at a time. Put a rod in a collet. Zero the dial indicator against the rod, move away from the dial indicator 0.500 inch and then back towards it 0.500" (program control) and re-zero the dial indicator, then move towards the dial indicator another 0.500" note the reading on the dial indicator. Then under program control move back 0.500 inch towards the original position note the dial indicator reading. That will give you a feel for whether it is moving the commanded distances or not. Alan
__________________ http://www.alansmachineworks.com |
| G100 Setup issues | gromit68 | Gecko Drives | 3 | 11-24-2007 10:09 AM |
| Setup Issues | Smitty911 | Mach Mill | 4 | 11-09-2007 05:04 PM |
| Super X3 setup issues | dafowfidy | Syil Products | 9 | 03-22-2007 12:09 PM |
| Accuracy issues | itsme | Benchtop Machines | 16 | 10-29-2006 01:17 PM |
| Accuracy determination & accuracy improvement | rweatherly | DIY-CNC Router Table Machines | 5 | 08-11-2005 08:37 AM |
