I can't ever get any return e-mails from Syil America (Richard) so I have decided to build my own high speed setup on the Sx3 I have. Does anyone know the pulley info and the belt size that replaces the original. I know that Neil has one but I though maybe someone has documented what the sizes are on the belt and toothed pulley for the motor side. I'm guessing it is a 1:1 pulley and matches the spindle pulley, but I want to be sure. Thanks Chris |
| I replaced the spindle bearings recently and the loads and rpm ratings on the lowest one was 10k. If I can get this info, I plan to take this to 6k or so. I think maybe Pizzamker has already done this with his. Maybe he can give us some guidance. |
| Here is the post with the Bearing numbers, I used these to purchase what I have. http://www.cnczone.com/forums/showthread.php?t=50760 Oddly, during my search for the spindle bearings, I also found someones pic of the upgraded speed pulley. It is here. http://www.cnczone.com/forums/showthread.php?t=45155 Thanks old megawatts. |
| I did the whole thing. Honestly though, the press fit back into the shaft took a lot more effort than I had hoped. I used a hydraulic press to get the shaft back in to where it was, and it didn't go in easy. I packed the bearings with high temp bearing grease and it did seem to help. also, I had to use the original race at the spindle, there is no way to get that out of the shaft housing. Not without major destruction. That in my opinion was a bad (read Throwaway) design. |
| I have started the build on the pulley and High speed mod. I am using Aluminum round stock for it. I had some 3.5" 6061 that needed a purpose anyway. I will post a cad file of the pulley and the details of the belt, etc once I make sure all specs are correct. I got the bare stock turned down and bored for the shaft. All I like now is to cut the grooves on the sides and then broach the keyway. Then it is 3x00 RPM..... (well, as soon as the longer belt comes in. lol!) I do know that the belt is a 5mm pitch and that the pulley has 45 grooves. Measurements indicate that the new belt is going to be a 95 tooth belt. We will see when it gets here. Now that I finally got my 4th axis finished a couple of days ago, this will be a good test for it. The real fun begins. ![]() Original belt is a 5MM pitch, 20mm wide, 400series 80 tooth belt for reference. |
| Earlier this year I purchased the pulley speed upgrade kit from Syil for the SX3. I had to; I think I looked everywhere, and could not find a 'stock' pulley for this application (bore/tooth spacing). It is amazing how these 'mass production' machines never seem to employ mass produced parts! Seems like maybe they had a deal on 100K spindle motors, except they were some random shaft OD and key width, etc, so they figured- cheaper to run some pulleys than to retail the motors... Anyway, it is a great upgrade if you are using 1/4"-3/8" cutters in Aluminum or similar. It is still slow for 1/8" cutters, or higher speed maching with carbide cutters, etc. If you need some data/pics, let me know. Strange, I had recently written to Richard at Syil, and never heard back either. I hope things are OK with him. Regards, |
#12
| I hope all is well with him also. I had sent him at least a couple of e-mails asking to buy something from him. I know the shock was at least 3 e-mails. I was ready to buy the speed upgrade kit and also the factory shock lift. I just needed payment info. Instead I wound up making the counter weight and now the Spindle pulley because I couldn't get a response. I would say that it could have been filtered by spam, but there were also 2 PMs from this board to him that went un-answered. Oh well, I gave my money to someone else. I think that Syil should have contacted Little Machine shop as a retailer. I think he could really move some products for them. It would be a one stop shop for parts and machines. That would be great. |
| High speed spindle... how high? | jonesja2 | General Metal Working Machines | 0 | 06-04-2007 07:18 PM |
| New Mini-Mill Two Speed Pulley Drive By Ron Steele | rustyolddo | Benchtop Machines | 7 | 02-12-2007 01:20 PM |
| High speed spindles in Aus? | Greolt | Australia, New Zealand Club house | 3 | 01-23-2007 06:47 AM |
| Mounting a Speed Sensor on a BP step pulley mill | titchener | Bridgeport and Hardinge Mills | 1 | 03-21-2006 05:02 PM |
| High Speed Spindle 10,000 to 40,000 rpm | whelen | Mechanical Calculations/Engineering Design | 5 | 09-05-2005 08:42 AM |
