Old 09-09-2004, 10:55 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
Making the HF mill run true and smooth
What I have found out about the bed of my mill is that it is warped. Because of this it was imposable to lap it and get it to run smoother and with-out side play. So the fix is to re-machine the ways and true the top surface. So if you have a HF mill you may have to do the same. I also found out that the dovetails were not cut the 60 deg they should to be, because of that the gib would not sit true. I also replaced the stock gibs with a brass one which really smooth out the movement.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 10-04-2004, 03:30 PM
rustyolddo is on a distinguished road
It's my understanding that the ways are machined to 55 degrees not 60 FWIW.
Old 10-04-2004, 03:33 PM
CNCadmin's Avatar
Site Owner
Yes but the gibs and the ways do not match, so I remachined them to macth using 60deg.
Thank You,
Paul G
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
