Results 1 to 9 of 9
Thread: Loose Emco PC Mill 30 X-axis
    Registered oxford's Avatar
    Mar 2008
    Question Loose Emco PC Mill 30 X-axis
    Recently bought a used mill and discovered a loose x-axis while doing maintenance.
    The Y and Z axis are tight and show no play.
    In the pictures, I tried to show the play in the axis. The looseness is back and forth around the x-axis ball screw.
    The first picture is where the z-axis mounts.
    The second picture is of the offending loose part.
    Is it possible to fix this problem with new rollers, or am I looking at a tough fix.
    Attached Thumbnails Attached Thumbnails Loose Emco PC Mill 30 X-axis-xaxisshimy.jpg   Loose Emco PC Mill 30 X-axis-xaxisloose.jpg
    Mar 2008
    Would better pictures be of use?
    Registered The Blight's Avatar
    Sep 2006
    Denmark
    Pictures from different angles (and better ones) might help some. You might also be able to find a manual on this mill. Looks like you should be able to find a screw somewhere that you can tighten down to reduce play.
    If there are screws holding the rollers in place, maybe you can tighten them down a bit. This way the rollers will be moved closer to the carriage and the slop will be reduced. The ideal sollution would be to use bigger rollers.
    Mar 2008
    I'll get some better pictures later today.
    I like the bigger roller idea. Any suggestions as to where to purchase?
    Mar 2008
    The rollers have a rim diameter of 20.02mm.
    Roller diameter within groove is 17.94mm
    Inner diameter of 9.93mm.
    8.52mm width.
    ...Looking for rollers slightly larger now:P
    Attached Thumbnails Attached Thumbnails Loose Emco PC Mill 30 X-axis-006.jpg   Loose Emco PC Mill 30 X-axis-008.jpg   Loose Emco PC Mill 30 X-axis-010.jpg
    Sep 2006
    Denmark
    Thanks for the pictures.
    Hmm.. You might get away with putting shims under the rollers (either the top or the bottom ones should do. You might also get away with just shimming one of them). This is really not a good sollution, because there will be less contact between the roller and the rail. The shimmed roller will only have contact on the inner lip (don't know what else to call it).
    How are the pins holding the rollers locked in place?
    Mar 2008
    They are held in place by friction.
    Sep 2006
    Denmark
    So a press fit. That makes it much harder. The only fix that I can see is to make bigger rollers. But you already know that.
    Mar 2008
    I spent too long looking for larger rollers online.
    I ended up going with your shimming idea.
    I took two thin pieces of metal and shimmed each of the loose rollers.
    Works fine now
    Attached Thumbnails Attached Thumbnails Loose Emco PC Mill 30 X-axis-fixed.jpg
    1. Help with Emco F1 mill
      By svon89 in forum Benchtop Machines
      Last Post: 06-06-2010, 05:54 AM
    2. Need Help!- Emco PC mill 50
      By Madog-Mitchell in forum Benchtop Machines
      Last Post: 11-10-2009, 06:34 AM
    3. I need some help with an Emco PC Mill 125
      By Cinci_State_01 in forum Benchtop Machines
      Last Post: 05-05-2008, 10:13 PM
    4. Emco PC Mill 30 Questions
      By lanb in forum Benchtop Machines
      Last Post: 09-24-2007, 01:00 AM
    5. Upgradeing a Emco F-1 cnc mill
      By woodythx13 in forum Benchtop Machines
      Last Post: 10-01-2005, 03:30 AM
