Old 06-08-2008, 10:15 PM
dragons_fire is on a distinguished road
cnc stepper torque
ive done some searching but couldn't really turn up much. does anyone know how much torque is needed for a RF30 mill/drill? i was looking at the hobbycnc kits that include steppers, and im not sure if i 305ox/in is too much or not enough. if its not enough, then i may be looking for recommendations for another setup (thats less than about $400). if its too much, then it would be great because i could go with cheaper motors.
i found one thread from Balsaman about his conversion, and somewhere in there it mentions that the motors he is using are around 100oz/in.
thanks
Old 06-12-2008, 09:22 AM
Robin Hewitt is on a distinguished road
It doesn't take much torgue to turn a handle on a ball screw (unless the Gibbs are way too tight). So you need to choose a motor that will hold it's torque at speed.
An oz-in rating for holding or pull in torque tells you very little about the motor, what you need is a graph of torque against speed.
For a stepper the graph will start of fairly horizontal then plummet, question is, is there a useable fast feed before the plummet?
Torque vs apmerage of stepper cut more Stepper Motors and Drives 6 06-06-2006 09:28 AM
Stepper Torque Problem electron Stepper Motors and Drives 15 03-23-2006 08:15 PM
Stepper torque extreme Stepper Motors and Drives 6 12-14-2005 04:09 AM
stepper torque swarfmacdaddy Stepper Motors and Drives 0 10-14-2004 06:53 AM
is there any easy way to know the torque of a stepper Urgundiz DIY-CNC Router Table Machines 3 02-05-2004 12:42 AM
