Has anyone figured out how to use Mach3 to control the spindle speed in the Super X3? I looked at the motor wiring diagram and could not figure out a way. It looks completely different from a regular X3 mill to me. Thanks, Bill Box |
This would seem to be the Holy Grail for some of us here. I have been looking for a solution for some time, without results. Here's what I have done so far: 1) I communicated with Syil America to see if they would sell me their solution separate from their CNC conversion kit. The emails from Richard were friendly, but he seemed intent on trying to sell me the complete electronic package including breakout boards, drivers, and power supply. I was only interested in the interface board that plugs in between the SX3 driver board and the front panel, but could never get a price on just that piece. 2) I also communicated with Arturo from CNC4PC.com. He has a solution for the regular X3, but has not yet created one for the SuperX3. I emailed him some schematics that user OldRaven from this board had traced out, and he seemed to think that would help him figure it out. He was also going to communicate with Seig to see if they could provide him with the necessary info. I have not seen any results from this so far. 3) There are several posts in the Syil support forum on this board that speak to this issue, but none with a solution. One user replaced the entire SX3 driver circuitry with another 3 phase amplifier that was externally controllable, but I didn't see any details as to manufacturer, cost, etc. So apparently there are many of us waiting patiently for a true solution. Welcome to the club. Hopefully the extra noise on the demand side will prompt some more attention. |
| From what I can tell, the Boards are being created for them by this guy. http://translate.google.com/translat...H_enUS271US271 So I doubt we will be able to order them through Syil or anyone else. The package that he has looks exactly like what is in the units I have seen pictures of. I may have some useful info, but I need to compare some things first. Devers6, I sent Arturo some specs from Grizzly's manual, as well as the photos of the control boards. He replyied back with some diagrams, but they still didn't match up with what I have for pinouts etc. It looked more like an edited version of the one on the website. Would you mind sending me a copy of those diagrams you mentioned? I have something that may be of interest to you also. I just sent him another e-mail offering to send him an SX3 for a test platform. Maybe he will accept and help us get this figured out. There is no doubt he can certainly figure it out. He has the contacts with Seig to get the original Diagrams and such, but as of yet, hasn't been able to. Maybe having the mill there to look at will solve this for us. |
| cjdavis, Can you post a pic of the main SX3 spindle board. I have some here but it's a UK one and could be different. On the UK machines there is a main spindle board that has a daughter board plugged into it. Then on a ribbon cable there is a front panel that has the stop start revs up / down and tapping - then a speed DRO board. On the KX3 CNC direct from Sieg it used the same main board and daughter board but the other two boards are missing and replaced by a small speed logic board that has it's own power supply and supplies 0 - 10 volt to the main board. This AP2 board is all that is required. ![]() John S. |
| Sure. Here is my Grizzly sx3 board. So where can this AP2 board be purchased, and does it allow us to keep the original manual functions. Such as the control panel and the tapping features? ![]() Wiring Diagram from Grizzly. |
| The AP2 board comes as standard on the KC1 and KC3 CNC mills from Sieg. I don't know if it can be purchased separately. It controls spindle speed and direction only and the KX series being full CNC's don't have the tapping feature. I can't help but to me it looks as if that ribbon cable from the control panel circuit board, which is the same as the KX setup, will have two of those wires carrying 0 - 10 volts or 0 - 5 volts ? for the variable speed. John S. |
| CR. |
| The problem is that we do not have a simple ribbon cable though. For some reason, that was changed to 18ga stranded wire in the molex. I went through the system yesterday with my DMM and found that almost all the cables on that run shows between 6.3 to 7.3 volts. None changed when using the buttons on the board to control the spindle. .....But, I am questioning my DMM now. There were some flaky things happening with it yesterday to make m think it isn't reliable. I am picking up a fluke today and will re-test. I have pics of the actual Control board and the Spindle Speed board now as well. Here they are. (note. the red and black lead at the top corner go to the Safety shield switch. That is not a voltage input) The plug on the lower right is the connector for the Spindle readout. The upper is the one that comes from the main control board. ![]() |
| Chris, Thanks for making me aware of this post. As I understand this, the external control board generates an analog 0-5vdc that goes through the ribbon cable. So the thing would be identify the wire that carries the analog signal and the ground. This does not sound like a very hard thing to do. Our speed control boards come with a pot, that would make it easy to take down the signal from 0-10 to 0-5vdc. Arturo Duncan http://cnc4pc.com |
#10
| On the Syil SX3 CNC the cable from the front panel that went to the bottom of the motor control PCB next to the bigger green connector is daisy chained to a PCB with 2 relays on it. The relays are for M7 and M8. The input to this PCB goes to the Break Out Board which sends the DC control voltage and direction signal. You need a revision 1.3 Spindle Control PCB to go with the piggy backed motor control setup. The 1.3 PCB using the BOB DC signals, fakes front panel stop/start/faster/slower buttons, and the whole arrangement cannot be made to work properly. The control strategy is flawed/dumb/stupid read that as badly engineered by east crystal. A redesigned 1.3 type PCB is all that can fix it. Picture of 1.3 PCB and BOB included here FYI.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
#11
| Thanks Arturo and Neil. I think at this point, it would be difficult to do anything but "simulate" the key presses on the mill. At least for full functionality. I guess like any design session. We need to decide whether we are after the full features of the mill, I.e. forward, reverse, tap or simply forward speed with rpm control. Obviously, at the very least, I would like to have the ability to control forward speed with the mill, but not removing the manual controls for simple manual tasks such as drilling and tapping. These would require the reverse and hand control button for tap. If there were a way to "tap" into the forward only controls of the mill, that would certainly be a start. I am putting some fence up at the moment, once daylight is gone, I will be back in the shop getting some voltage readings on the new meter. Neil, does your mill still give you all of the Sx3 functions? Tap and all? Along with Mach control of the spindle? If you do have Mach control of the spindle, do you have forward and reverse? |
#12
| It should be too hard to produce a DigiSpeed to go in-line, between the 2 pcbs, if there is enough interest. Would need a little reverse engineering, but should result in maintaining the original functionality plus a mode to be controlled by Mach3. Neil, I presume you have one of these mills? Cheers, Peter.
__________________ ------------------------------------------------- Homann Designs - http://www.homanndesigns.com |
| Spindle Speed Control for X3 with C11G BOB & Mach3 | MRM RCModels | Benchtop Machines | 24 | 07-26-2008 12:39 PM |
| Spindle speed and tach for MACH3 | chrispy | Mach Software (ArtSoft software) | 16 | 04-05-2008 08:25 AM |
| Router Speed Control + Mach3 + Breakout Board | Dingo745 | General Electronics Discussion | 7 | 06-19-2007 08:58 PM |
| BP CNC S1 Speed control with Mach3? | Jonne | Bridgeport and Hardinge Mills | 3 | 06-18-2007 02:31 PM |
| BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? | peter.blais | Bridgeport and Hardinge Mills | 9 | 08-08-2006 03:29 AM |
