Old 05-28-2008, 12:46 PM
pzzamakr1980 is on a distinguished road
HPDE Suitability For Gibs
I was curious how well making a gib out of HDPE or Delrin or its ilk would work for an X3 machine. The plastic is a lot more slippery than the standard gibs so you could tighten it down a bit more to eliminate slop and it would still slide well and not bind. Any thoughts. Thx
Old 05-28-2008, 01:02 PM
Delrin it is much more rigid than HDPE so it could be best, but how does it tighten down? Is it a taper gib or is the adjustment by means of a lot of set screws? With setscrew adjustment you may need to have a strip of steel bewteen the Delrin and the setscrews otherwise all that happens is the setscrew eventually chews a depression in the plastic and things get loose.
Old 05-29-2008, 01:27 AM
Thank you Geof, I didnt think of the steel plate but I will incorporate that into the design. And Delrin it is
Old 05-31-2008, 01:50 PM
tsalaf is on a distinguished road
UHMWPE is much better for jobs requiring low friction than either HDPE or Delrin.
Old 06-02-2008, 06:49 PM
sansbury is on a distinguished road
You are right than UHMW has higher lubricity than either material, but it is also significantly softer, which makes it very problematic for precision purposes. Simply machining the gib strips could be quite "fun" as UHMW has a nasty tendency to grab at tools, and it is so slippery it is hard to clamp without squeezing so hard that you deform the workpiece.
If I had to use plastic I'd use Delrin, though, I'd try brass first over any plastic. It is an improvement over the standard steel strips in terms of friction but still has plenty of compressive strength and won't wear anywhere near as fast as delrin-meets-cast iron. Lapping the gibs and ways is another way to reduce friction if you don't mind a little elbow grease.
Old 06-03-2008, 09:17 PM
Oldmanandhistoy is on a distinguished road
Have you seen Turcite B ® also known as Halar® ?
http://www.midlands-slideway-grinding.com/products.html
John
Old 06-04-2008, 02:35 PM
The Blight's Avatar
The Blight is on a distinguished road
I just spent 3 hours touching up the z axis on my X2. After that I started on the x axis, and when I was done lapping and scraping I took a look at the gib. Apearantly they have saved some money on not making proper groovs for the set screws on the gib. Seems like they just took some screws and torqued them down until they made dents in it. Because of this the gib is not lying flat against the slide, and so it has very little contact with the surface. This in turn gives a lot of slop. I might even end up making new gibs from brass. Will have to see if I can correct this error.
I once made a drawing of a steel gib for my mill with a delrin insert. Never got around to make it though
Old 06-04-2008, 05:09 PM
cjdavis618 is on a distinguished road
I've watching this thread with interest. I did a quick search and found this place in the US that carries this as well. Also give basic instructions on how to use and install it.
http://www.mtsandtg.com/specialty/products
UHMW-PE Suitability for Belt drive pzzamakr1980 General Metalwork Discussion 11 11-24-2007 06:58 PM
Taper gibs vs Parallel gibs Oldmanandhistoy Linear and Rotary Motion 0 09-08-2007 07:25 PM
Suitability of G Code for extruders Bhima G-Code Programing 0 05-24-2007 12:58 PM
DC motor suitability? QSIMDO Industrial Hobbies (Support forum) 5 04-15-2007 10:14 AM
Stepper Motor Suitability? unicorn13 Stepper Motors and Drives 9 01-08-2007 04:36 AM
