Old 05-21-2008, 08:28 PM
alchemistAZ is on a distinguished road
what to use for router head?
hi,
All of the DIY router plans use a dremel motor as th router head. I assume this is fine for wood but won't hold up to aluminum. I read one website that tried a couple of homedepot routers but they still weren't very good with small bits. they wabbled too much. What and where would I get an appropriate router head for milling aluminum, of course on the low cost side of things.
Thanks,
Michael
Old 05-21-2008, 10:42 PM
tsalaf is on a distinguished road
I’ve been using a Makita RF1101 for cutting aluminum (actually, two Makitas). They don’t last and need constant repair. They have approximately .005” of radial runout and .003” axial runout. This makes for a poor finish and short tool life. You can forget about using small diameter cutters (under .125”) without breakage.
I suggest going with a milling head such as from a Taig or one of the Chinese machines.
Old 05-22-2008, 09:22 AM
KTP KTP is offline
Gold Member
KTP is on a distinguished road
yes, I am doing the same thing tsalaf suggested. I have a bosch wood router mounted to a dovetail slide on my router, and also a Taig 10k rpm ER-16 collet spindle that mounts to the same dovetail. I can swap them out in under 20 seconds. The Taig spindle is driven by a 500 watt brushless servo.
There is a pic of it in my thread, although I need to take some more pics of the Taig spindle now that it is done.
Fixed gantry router
building a router...im my head .xXACEXx. DIY-CNC Router Table Machines 4 05-31-2007 11:28 PM
Floating head on Kress router zoltan Mechanical Calculations/Engineering Design 3 03-02-2007 08:52 AM
router head getting stuck in z postion? ilovewood Commercial CNC Wood Routers 2 01-24-2007 06:10 PM
router head for engraving-opinions please? metlcutr55 CNCzone Club House 0 12-16-2005 04:58 PM
circuit to turn on router head treemagnet DIY-CNC Router Table Machines 9 03-24-2004 10:15 PM
