  #13   Ban this user!
Old 05-20-2008, 04:02 PM
wwendorf is on a distinguished road
I'll get there eventually. For now, 3400 works for prototyping.
Wade
  #14   Ban this user!
Old 05-20-2008, 04:21 PM
shanepeed is on a distinguished road
Coatings
ZrN coatings also work when machining aluminum. It helps to keep the aluminum from sticking to the tool. When I ran my shop I ran tools at highest rpm's available. Worked very well and I had good tool life.
  #15   Ban this user!
Old 05-20-2008, 04:36 PM
Bird_E is on a distinguished road
My X3
I'm running an X3 with a 1/2HP VFD belt drive, typically run about 3200 RPM,
1/2" two flute HSS endmill cutting Alum, .030 DOC @ 35IP works good for pocketing / profile, Just using compressed air to clear chips. With no coolant much more then .030 DOC . chip welding becomes a real big problem.
OH, it vibrates like hell when it's plunging... no matter what feed!
Once the x/Y cut begins it sounds sweet.
I nice sharp quality cutter makes all the difference!
My Site:
http://www.rlberg.com
Bob
  #16   Ban this user!
Old 05-21-2008, 09:52 AM
dneisler is on a distinguished road
Thanks for all the input guys, I got sick and have not had a chance to mess with it.
Bird E
What exactly are you using to get "X3 with a 1/2HP VFD belt drive, typically run about 3200 RPM," I am working on a belt drive and looking for motor upgrades.
***For full up to date details visit my blog @ www.donald-neisler.com
Donald Neisler
  #17   Ban this user!
Old 05-21-2008, 09:59 AM
Do a ramping cut of some sort instead of a straight down plunge cut. Or plunge at 1 ipm and you won't have as much of a vibration issue.
Wade
My Site:
Bob
  #18   Ban this user!
Old 05-21-2008, 06:23 PM
sergizmo is on a distinguished road
My Site:
Bob
Bob,
You could try pre drilling your plunge holes. If the pocket is .5 deep drill to .49or so. Then at the final end mill plunge do so at 1 or 2 IPM.
Serge
Old 05-22-2008, 08:57 AM
KTP KTP is offline
Gold Member
KTP is on a distinguished road
On my Shizuoka bedmill, which is 6000 to 7000 lbs, I plunge with a half inch endmill at no more than 2IPM in aluminum. Endmills are not really meant for drilling, they are best at side cutting.
  #20   Ban this user!
Old 05-22-2008, 09:13 AM
Well I got to spend a little time as I finished up a project for someone to take a look. It appears my Y axis gib has worked it's way a little lose, so I am sure that is affecting my finish on Y axis cuts and viberation. I hope to get more time today to tighten it up and recheck some other things too. Will report back shortly.
Donald Neisler
  #21   Ban this user!
Old 05-23-2008, 01:35 AM
AirHog is on a distinguished road
My X3 (Grizz) would cut just like you describe just a few days after i got it. I couldnt do any depth without a lot vibration, and the surface finish was horrible. I finally tracked it down to the spindle, the "C" nuts that hold the preload must have moved just a hair out.
After i cleaned it up (since it was out) and readjusted the preload, the finish went from the worst I've ever seen, to mirror like. I was also able to get huge DOC's again. Worth a shot.
  #22   Ban this user!
Old 05-23-2008, 09:33 AM
Good info, I already to need to replace my bearings I think, they make noises badly. So I will check all that when I open the spindle up sometime. Kinda scared to take that appart.
Donald Neisler
  #23   Ban this user!
Old 05-24-2008, 05:08 PM
skullworks is on a distinguished road
Arrow All you need to know...
Scared to take it apart...
OK. Get the set of instructions put togather by the fine folks at Arc Euro Trade. They explain everything in great detail with color pics.
I'm not going to link directly to the PDF, but it is right there on there X3 mill page.
I just wish there was a good US distributer that offered there level of prep service in the U.S.
  #24   Ban this user!
Old 05-24-2008, 05:13 PM
Not really scared but with my luck something always be wrong or go wrong. I don't have good luck at all. I have there PDF, it doesn't look to hard other than I don't have a press.
Donald Neisler
Best milling finish on 6061 SRT Mike General Metalwork Discussion 17 03-31-2011 09:35 AM
Need Help!- aluminium 6061 milling sharathchandar General Metalwork Discussion 12 04-13-2008 10:34 PM
Using Roughing EM on 6061 mrk CNC Tooling 8 05-31-2007 11:27 AM
Milling some 6061, want to move lots of metal, what feeds and speeds? Loading General Metal Working Machines 9 06-27-2006 01:43 AM
End-Mill bit 6061 Ed Williams General Metalwork Discussion 2 05-31-2006 11:18 AM
