Old 05-19-2008, 01:16 PM
jon003 is on a distinguished road
Vise size for Manual SX3?
I've just fired off an order for a G0619, which I'll be running in manual mode for a while.
I'm looking at Kurt vises, and I'm not sure which size would be appropriate for a 6x21 mill @ ~400 lbs.
I'm leaning towards a 4".
Old 05-19-2008, 01:42 PM
wwendorf is on a distinguished road
I bought a 6" kurt clone. It works, but it's BIG and almost a bit too tall for me to work with effectively. I wish I had bought a 4" instead. Everything works on it fine, unless you start getting into using over .25" drills. That, combined with the jacobs chuck make it a little hard to clear your workpiece sometimes. I've wound up on the VERY highest point in the Z axis and barely had enough clearance to get to my workpiece. I am on a CNC SX3, but I thought the info was relevant.
Wade
Old 05-19-2008, 01:47 PM
Definitely relevant. Thanks!
Old 05-19-2008, 01:53 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
What's the largest object you need to HOLD in the vise? The Kurt 4 inch (Angle) vise opens to almost 4 inches and weighs 32 LB. The 6 inch opens to 7.5 inches and weighs 78 LBs. The 8 inch vise opens to almost 9 inches and, at 159 LBs exceeds the table limit.
The SX3 table can hold a maximum of 150 LBs, so it's a trade off if you also intend to mount a rotary table.
Those vises are REALLY expensive. If you don't really NEED the last nth of precision--there are lots of viable, almost as precise, less expensive vises.
CR.
Old 05-19-2008, 04:08 PM
tauntdesigns's Avatar
tauntdesigns is on a distinguished road
I got a 5" vise for my X3. Here's a couple of pics with it setting on the end of the mill.
ID:	59877   Click image for larger version
Walking is highly over-rated
I NEED: DX-32 manual, 1104-2832 VMC Operator's Manual, DX-32 CNC Control vettespeed Bridgeport and Hardinge Mills 25 05-01-2011 07:50 AM
Drawing Size and Cut Size Differ - Plasma ADucci LinuxCNC (formerly EMC2) 5 10-05-2007 05:52 AM
Drawing Size and Cut Size Differ - Plasma ADucci Mach Plasma / Laser 0 10-04-2007 09:49 AM
X3 base size or minium bench size kenrc Benchtop Machines 2 02-04-2007 07:50 AM
Home Made Vise Stop - For 6" Kurt Vise widgitmaster Bridgeport and Hardinge Mills 20 12-15-2006 09:49 AM
