| Late April into May, possibly the the ****tiest month on hand in the shop. So you guys know my C11 board went up in flames. New board sent, Coolant pump would not turn on with the board. Sent back, new one sent. Pump still does not turn on with new Board, same settings, same hal config. Same everything! Today the last week and half the pump starts too sputter (After c11 went into flames) turns out today, after much testing. I'm pretty sure the pump is now ruined, it barely has an energy too pump (it won't even come close too pushing coolant up the line). So after the c11 went up in flames, i'm pretty sure it some how messed my pump up too. So, relay for coolant pump does not work, pump now broken. And on top of that, I am backed up by about 3 weeks of work. Pretty good month....... ![]() How are those 5-7 pumps at surplus center? I need one quick I guess. I'm in such a bad mood today! -Jason |
| Are you sure that a fault with the pump wasn't what blew your C11? Sorry to hear of your bad month. |
| No way, It was working great. The pump was fine, the C11 just blew one day. |
| Speeds I know its convient to have everything done up in one board but to this day I still kick myself for having all 3 axis on one board. Coolant shouldnt take down the whole mill. Its a nice item to have but plugging in the pump would have worked just as good until a new relay was sent. Take it as a learning lesson and exchange the board for a c1,c4,c5,c6. You will have all the same features as the c11 for about 20.00 more but if one fails the rest will continue on. Hope things will work out for you. I dont like being behind myself, it just adds to much stress. |
| I use too just plug it in, but it ruined the pump ![]() -Jason |
| Jason, I'm sorry to hear about your troubles. As for the pump, Im not sure which pump you're talking about, but here is the one I had been eyeing: http://www.surpluscenter.com/cart.as...54662&catname= Unfortunately it looks like they're sold out now. I did find them somewhere else when I googled it, but double the price : http://www.skycraftsurplus.com/index...OD&ProdID=1045Still not a bad price though. I think this is the same pump Hoss is using, so maybe ask him about it before purchasing it. Best Regards, Andy |
| They have pumps on there: for like 6.00. May be worth trying. -Jason |
| Just some thoughts that might help you.... Let's see, you bought a surplus coolant pump, it failed and you are certain its failure is caused by the C11 I/O board? Are you sure that the pump (being wet) didn't short circuit and cause the C11 failure? How did you verify that the C11s failure caused the pump to fail? How did you determine that the pump didn't fail which in turn caused the C11 to fail? Do you have fuses on your high powered devices? Did you have a fuse between your coolant pump and the C11 board to protect it from short circuits? If I were in your shoes, I would spend a lot of time going over that machine checking everything electrical - especially the high voltage stuff. For something so critical to your business, you shouldn't be short changing yourself by not looking into the problems properly. Chris |
| You can still get Hoss's pump, shipped very quickly, HERE: http://www.surplussales.com/Motors/Motors-7.html CR. |
#10
| CR: Nice find, thanks! bookmarking that page. Jason: the thing that concerns me about the $6 pumps on surpluscenter is the max head pressure, seems really short. - Andy |
#11
| yw, Andy! That's where I got mine. It's brand new. CR. |
#12
| The 900 GPH pump works great, no problems. Forget the little $6 pumps, got one first and it couldn't lift more than 2 feet. Maybe I'll use it to make a little Feng Shui Water Fountain.
__________________ http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com |
| What the hell can I do? | orionstarman | Hard and High Speed Machining | 14 | 11-23-2010 12:00 AM |
| I'm in CNC Hell---Somebody help me | Shinosky | Benchtop Machines | 1 | 10-28-2006 06:41 PM |
| I'm in Tap and Die Hell | samualt | DIY-CNC Router Table Machines | 24 | 06-03-2004 12:00 AM |
| CAD software discount (this month only) | HomeCNC | Product Announcements & Manufacturer News | 3 | 10-17-2003 10:34 AM |
