Old 05-12-2008, 02:01 PM
IanH is on a distinguished road
Conect (sic) mill
Help! Has anyone any information on the UK schools' mill from CONECT. I have been given one and replaced the stepper drivers and it works but I would like to know which company built the mill for CONECT.
Ian Hart
Old 05-13-2008, 05:20 AM
Stepper Monkey is on a distinguished road
I've seen a number of lathes labeled under that brand name, and they just looked to be CNC converted Myford lathes of a pretty old style, and mounted in a steel enclosure. D&M was another brand name on some of the same units. Don't know how that ties in though. Hope that gives you a bit of a start at least.
Never seen a Conect mill however, don't know what it would look like or what maker it originally came from. Maybe if you post a pic someone will recognize it.
Old 05-13-2008, 08:40 AM
I will post a photo as soon as I have time and finished current task.
Old 05-16-2008, 10:38 AM
MIKE JEFFERS is on a distinguished road
boxford made some of this stuff i think
Old 06-02-2008, 10:07 AM
Photos of CONECT machine
Here is the machine, in all it's glory. Anyone recognise the manufacturer.
ID:	60756   Click image for larger version
Old 06-02-2008, 11:51 AM
praetor's Avatar
praetor is on a distinguished road
Servo motor
is that a servo motor driving the spindle..if so, how's it run? I have a small servo motor and would love to run have it run a little boley lathe, any ideas?
and is the plate on the conect mill a inf plate?
Old 06-02-2008, 03:12 PM
The Blight's Avatar
The Blight is on a distinguished road
Thats a beautfil lathe you have there. And it also looks like a servo motor, but I don't know what type of encoder that is.
We have several boley lathes at work, and I just love seing those old machines doing their thing.
Old 06-02-2008, 04:54 PM
Al_The_Man's Avatar
You didn't say what voltage it is? I would guess 60~80 v?
Otherwise for 90vdc, you can use one of the KB/Baldor scr drives, right off the 120vac line.
I would even suspect they will run at lower AC in if a step down transformer was used.
If much lower, get one of the AMC or Copley servo drives off ebay.
It appears not to have a tach, so it may not run as well in open loop as a velocity mode.
Old 06-02-2008, 07:01 PM
Mill Motor
Hi
The motor is a DC motor. the rating plate says:- 130v, 37A, 4000rpm
It's UK 230-240 volt AC
Old 06-02-2008, 07:46 PM
Al_The_Man's Avatar
Originally Posted by IanH View Post
Hi
130v at 37a is a 4kw (~6.5hp) motor? Sure its not 3.7A?
It sure doesn't look THAT big.
From the apparent size in the pic. I would think that 37a is the demagnetization point, not the stall torque current.
  #11   Ban this user!
Old 06-03-2008, 10:08 AM
Question Rating Plate
Hi
I keep checking the plate and it says 37A and the digit spacing doesn't appear to leave space for a missing decimal point. It is a SEM 'Ferrite Brushed DC Servomotor'.
  #12   Ban this user!
Old 11-05-2008, 05:55 PM
JQ_Quint is on a distinguished road
hi Ian,
I have been searching the forum for threads on the conect minor mill and found yours. Did you find any more info? I am awaiting mine to be delivered at the moment but i am expecting to have to convert it to run off mach, it is coming without any pc/software you see. Have you had to do the same?
The only thing i have found so far is that the company maker is called Conect Numerical Controls Ltd. Thats all i have at the moment.
Mine does look the same as yours except it is in an enclosed box.
Any info would be appreciated.
J.
conect cnc lathe retrofit daedalus Vertical Mill, Lathe Project Log 27 08-29-2010 08:55 PM
Conect Numerical Control 250 router NoTech Mach Mill 10 06-15-2009 12:55 PM
Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head fignoggle Benchtop Machines 18 05-12-2009 12:11 AM
Conect (boxford) CNC software mfrank7143 General CNC (Mill and Lathe) Control Software (NC) 10 04-30-2009 05:46 PM
Bridgeport mill conect to pc pestana1957 Bridgeport and Hardinge Mills 2 11-27-2006 05:52 PM
