Old 05-11-2008, 11:12 PM
Hellbringer is on a distinguished road
no motor movement??
hi,
i just fnished building my cnc contorler and i hooked it up to a computer and i do not get any motor movemnt and i do not know why. i am using the keling 3 axis setup with 425oz stepper with the kl-4030 drivers.
i hooked up the wires the way the wireing diagram says to with some switches to be able to turn off the 5 volts and the 120 volts. (2 switches)
wires from the motors. there are 8 wires that come for the motors 2 wires go to each 4 connectors correct????? so it comes down to having 4 wires (B- you connect the green AND the black wire, B+ connect green/white AND black/white and so on) is that correct?????
i found another wiring diagram for the KL-4030 and it shows that instead of pulling the 5 volts from the 5 volt power pack it connects the wire to the COM port inbetween the motor pins ont he breakout board (ex pin order: pin 2 - com - pin 3) so this diagram has a wire from pin 2 to DIR CW- then COM to DIR CW+ and STEP CP+ then pin 3 to STEP CW-. which way should it be hooked up or does it matter?
as a computer controler i am using mach 3. i have set it up the way the video turtial says to on mach 3 website and they way the turtoial in the kelings website (they are the some) and still do not get movement. i dont know what i am doing wrong
the only question i have for the software side is in the ports and pins the all the way on the right it says step port and dir port and it going to be 1 correct because i am using port 1 in the port setup
thanks in advance
Mike
Old 05-11-2008, 11:59 PM
jalessi's Avatar
jalessi is on a distinguished road
Mike
Keling stepper motor wiring is as follows:
B- = green and black wire
B+ = Green\White & Black\White
A- = Blue & Red
A+ = Blue\White & White\Red
Repeat wiring for each motor to each driver
Please provide your email address or a instant messenger so I can send additional wiring information.
Jeff Alessi
jalessi@aol.com
Old 05-12-2008, 12:07 AM
jalessi's Avatar
Select 1 for Step Port and for Dir Port
Old 05-12-2008, 12:08 AM
jalessi's Avatar
Are you using a Keling BOB?
Old 05-12-2008, 12:11 AM
yeah i bought the package..... the board is from cnc4pc but i got it from keling i think then call it the c10
also email is misterg0531@gmail.com
thanks mike
Old 05-12-2008, 12:23 AM
jalessi's Avatar
BOB Wiring
BOB TERMINALS STEPPER DRIVE TERMINALS
Connect BOB 2 to: (DIR) CW-
Connect BOB COM to: (DIR) CW+ AND (STEP) CP+
Connect BOB 3 to: (STEP) CP-
Old 05-12-2008, 12:25 AM
ok thanks i will try that
mike
Problem- no motor movement??? Hellbringer Automation Technology Products 26 06-09-2009 01:49 AM
Help! - MM2001 & GMFC motor movement DreamerM Foam Cutting Software 1 10-09-2008 11:06 AM
No motor movement Nitroghost Stepper Motors and Drives 30 10-05-2007 11:03 PM
Sporadic axis/motor movement suddenly started in Mach3! boothie Mach Mill 2 08-20-2007 07:21 PM
No Movement wishmasterg Mach Mill 3 02-14-2007 07:39 PM
