  #13   Ban this user!
Old 05-11-2008, 09:21 PM
blackbeard52 is on a distinguished road
Are you using mach3? if so check out earnie's mod blue screen...it seems to work fantastic. http://www.cnczone.com/forums/showthread.php?t=56079
  #14   Ban this user!
Old 05-11-2008, 11:20 PM
archerks is on a distinguished road
Been gone all day, lo of repsonses to my post.
The laser line is around .025" thick.
You could offset the mount, say to point at the corner of your vise but it would be very difficult to properly align the lasers. If you notice in my picture there is a white rod in the chuck, this has a vertical line on it that is used for alignment.
Seems to be a lot of interest for a touch pad, so in the next couple of days I will write up a how to with screen shots.
Dave
  #15   Ban this user!
Old 05-12-2008, 10:56 AM
fretsman's Avatar
fretsman is on a distinguished road
Thanks for the info, Dave, much appreciated -
Dave->..
  #16   Ban this user!
Old 05-13-2008, 03:16 AM
Stepper Monkey is on a distinguished road
Do they have a mounting attachment for sharks?
  #17   Ban this user!
Old 05-13-2008, 05:52 AM
Usually a board....at least in the restaurants I have been to. lol
  #18   Ban this user!
Old 05-13-2008, 10:12 AM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Interesting! Would help me putting my endmill right on a corner! Hmmm nice idea.
-Jason
  #19   Ban this user!
Old 05-13-2008, 04:47 PM
pete from TN's Avatar
pete from TN is on a distinguished road
Can't I have friekin' sharks.....
Man can't I have friekin' sharks with friekin' lasers attatched to their friekin' heads. Dr. EVIL, Austin Powers EVEL nemesis.... peace all..
P.S. love that movie, Heather Graham = humannna humanna humanna...
  #20   Ban this user!
Old 05-13-2008, 05:05 PM
LeeWay's Avatar
LeeWay is on a distinguished road
Actually I have thought about putting a laser pointer on my shark guards for table saws.
Finding then small and cheap enough is really the only issue so far.
I went ahead and ordered one of these. It should work out perfect for the way I run my mill.
I can either seal it up or I can mount it to the top front of the X2 head. That would be out of the coolant there as long as it's not in the way.
Thanks for the links and the heads up.
Lee
  #21   Ban this user!
Old 05-16-2008, 09:33 PM
LeeWay's Avatar
The laser came in today. I don't want to hijack your thread, but I thought it might be a good place to show mine. I had to modify it some to fit an X2 head. I want to thank you, Dave. This thing works great. After some fine tuning that is. I had my doubts that it would work on the front rather than the rear or column mounted, but after playing with it, it kept getting closer and closer and bingo. Perfect at all heights.
The little secondary paralleling lens were the key.
I mounted this in some existing holes on an X2 head. These holes were for the splash guard. Then a piece of aluminum angle. Drilled and tapped a few holes. I had to saw off the column mounting portion of the housing on the laser. I also had to shift the little circuit board inside to get enough wire to twist the left laser around backwards. The other had plenty. I also sealed the battery door. The top comes off with two cap screws to easily access the battery the way I mounted it.
It sure makes quick work of locating my plates and even the corner of something in my vice. This for me is a real time saver. No more need to lean into the enclosure to zero the Y.
ID:	59723   Click image for larger version
ID:	59724   Click image for larger version
ID:	59725   Click image for larger version
ID:	59727   Click image for larger version
Lee
  #22   Ban this user!
Old 05-17-2008, 07:20 AM
fretsman's Avatar
Beautiful job, lee, and thanks for sharing.
May I ask what kind of tolerances you're working in?
Dave->..
  #23   Ban this user!
Old 05-17-2008, 07:47 AM
LeeWay's Avatar
Thanks. The machine is capable of .001" repeatability. The jobs I cut on this mag chuck will soon be done with my plasma cutter, so plasma is close enough for these.
I make some brackets and clamp parts using steel and aluminum and it is good enough @ .005" tolerance. Actually for alignment on all of the parts, .01" is plenty close to center or edge or corner, depending on what part I am cutting. My blanks are generally a hair over sized anyway.
This little machine does way better than I expected or needed, but can't complain about accuracy when theres more of it than you need.
Lee
  #24   Ban this user!
Old 05-17-2008, 10:52 AM
fretsman's Avatar
Can't argue with that!
Dave->..
My DIY Edge Finder multiplex DIY-CNC Router Table Machines 40 05-25-2010 11:46 AM
Has anyone used this edge finder? l u k e General Metalwork Discussion 34 03-19-2008 01:52 PM
Where to specify edge finder diameter? JMFabrications Haas Mills 7 07-19-2007 12:04 AM
Laser edge finder dave6 Calibration & Measurement 9 12-10-2006 09:06 AM
Acronym finder ynneb FAQ of CNC Machine building 0 10-27-2004 06:13 PM
