Old 05-09-2008, 11:30 PM
MRM RCModels's Avatar
MRM RCModels is on a distinguished road
Opposite of Backlash?
Yep, it's not a trick question.
I just completed my X3 cnc conversion and have been making quite a few parts. I've adjusted all of the axis's to 0 backalsh at 0.5in and 5in. I can repeat this 10 times without fail. My only problem is that all of my parts are 0.01"-0.008" over the perspective measurement in the X and Y axis. I'm pulling my hair out on this.
Anyone have an idea on how to fix this?
Old 05-09-2008, 11:37 PM
Khalid's Avatar
Khalid is on a distinguished road
just check ur tool dia again and also check for run out in tool holder....
Old 05-09-2008, 11:50 PM
I checked for run out in the tool holder: less that 0.001 at full rpm. What did you mean by check to tool diameter? Do you mean in Mach 3?
Old 05-09-2008, 11:52 PM
jalessi's Avatar
jalessi is on a distinguished road
Runnout
Have you checked for a burr in the tooling or dirt inside the collet?
Old 05-10-2008, 12:00 AM
Check for dirt? Now that's something I haven't done yet. Would that really make that much of a difference?
Old 05-10-2008, 12:14 AM
Khalid's Avatar
Check the diameter of tool with Vernier calliper. If its right the other thing may be the STEP/UNIT to be corrected in Mach3 for both X and Y axis
Old 05-10-2008, 12:17 AM
Khalid's Avatar
Draw a circle of about 50mm diameter and check whether the circle is round or not...Check the diameter readings on 0-6Oclock and 3- 9 Oclock.
jalessi's Avatar
Dirt
If you have small pieces of any type of debris in the collet or between the collet and tool or spindle it could cause additional runnout.
Since you have checked for runnout and you only have .001 then its not really bad however that could be .001 on all sides of what ever you are cutting.
Old 05-10-2008, 12:19 AM
Khalid's Avatar
Draw a circle say 50mm diameter and check the 3-9 oclock and 0-6 oclock readings...
Old 05-10-2008, 12:25 AM
Khalid's Avatar
May be the case... if u gave the tool dia 3mm in ur CAM program and actually the tool u are using in ur machine is 3.2mm also with a little bit run outat the tip of ur tool.....u will be having the same trouble..
just my 12 x 70000/12 cents...
  #11   Ban this user!
Old 05-10-2008, 12:39 AM
tauntdesigns's Avatar
tauntdesigns is on a distinguished road
If you had to set your steps very far from 10160, I'd say something is loose and moving around some. Spanner nut pre-loading bearings? A block not fully tight?
When I got my kit, I put in 10160, and every move in the same direction checked dead on and when I changed direction there was .0007" backlash and every move in that direction was dead on.
After saying all of that,.......... Yea, I don't know either! sorry
Good luck,
Jack
P.S. If you had dirt or something in the collet, the endmill can get out-of-round. You can check that by putting an indicator on one of the flutes of the endmill and spin the spindle.
Walking is highly over-rated
  #12   Ban this user!
Old 05-10-2008, 12:56 AM
Khalid's Avatar
Just spin the spindle by hand
rotating 0,0 point to opposite corner. Vortex_bits G-Code Programing 49 03-24-2008 01:05 AM
Backlash or motor tuning problem? How do I test for backlash? Brian Queen Mach Mill 8 03-10-2008 04:35 PM
Need Help!- Backlash rodzilla Benchtop Machines 4 02-18-2008 12:07 PM
Make 2 parts symmetrically opposite kprice1658 Mastercam 3 12-17-2007 11:21 PM
Servo idea - elimated backlash - zero backlash ! synthetiklone Linear and Rotary Motion 6 12-06-2006 02:35 PM
