  #25   Ban this user!
Old 05-18-2008, 10:36 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
A note on the subject of limit switches with stepper motors:
FIRST, Different tools have different heights. This makes it almost impossible to limit lower travel of a Z axis without also limiting your tool choices. Most mills don't NEED a lower travel limit switch on the Z axis.
On a SERVO system, If the servo hits the end of travel and stops, it will keep on trying to go until it quickly overtemps and destroys itself. So limit switches are ABSOLUTELY NECESSARY on a servo system.
On a STEPPER system, if the motor reaches end of travel and stops, it will simply stall. There is no danger to the motor unless it is traveling at a very high rate of speed. So in a conversion without ballscrews, the speed is most likely to be low enough to forego the use of limit switches.
Mach3 allows the set up of "software limits" which perform travel limiting quite adequately without added complexity.
CR.
  #26   Ban this user!
Old 05-18-2008, 11:05 AM
cyclestart is on a distinguished road
Originally Posted by Harryman View Post
If you need a Porche though, you need a Porche.
Nonsense.
You may need a 3/4 ton truck. You desire * a Porsche. Chasing precision for it's own sake is no bad thing as long as you're aware that's what your doing, It can be a desire thing.
*Unless you need to pick up women. There the Porsche has few equals
Anyone who says "It only goes together one way" has no imagination.
  #27   Ban this user!
Old 05-19-2008, 11:44 AM
philbur is on a distinguished road
Yes but if you need to go round corners real fast you will NEED the Porche.
Phil
Originally Posted by cyclestart View Post
Nonsense.
  #28   Ban this user!
Old 05-19-2008, 02:46 PM
Ron111 is on a distinguished road
Any links to info on the New Gecko 540 board?
Thanks,
Ron
  #29   Ban this user!
Old 05-19-2008, 03:13 PM
Get your coffee and snacks ready and settle in. This will take you awhile:
http://cnczone.com/forums/showthread.php?t=51083
CR.
  #30   Ban this user!
Old 06-11-2008, 05:40 AM
Thanks,
Ron
Latest info with pics and manual on this page, post #892:
http://www.cnczone.com/forums/showth...462207#post892
CR.
3 phase input VFD for single phase input? Redhead Phase Converters and VFD 4 02-27-2008 10:30 AM
Choosing the right path. New or Used? Prebuilt or Retrofit CNC? w0067814 General Metal Working Machines 2 12-06-2007 04:00 AM
A Honeywell 9100e Controller upgrade path? cage_and_alam General CNC (Mill and Lathe) Control Software (NC) 0 02-08-2007 10:25 PM
Change - from linear path control to CNC path control fidibus42 General Electronics Discussion 1 12-04-2005 10:43 AM
seeking input on large scale-up of toy dberndt General Metalwork Discussion 22 01-12-2005 06:27 AM
