Results 1 to 6 of 6
Thread: CNC Fusion X2 Ballscrews, Y screw is too long.
    Registered spaceballs_3000's Avatar
    Apr 2008
    Just fyi in case anyone runs into why they can't mount their Y screw.
    My Ballscrew came over a little 1/4 inch too long and was hitting the X2 Mill base, after a quick grind, all was well.
    Also CNC Fusion should ship Spanners for the spanner nut, as I ended up using large tools to get that nut on. But ended with teeth groves on the end of the shaft where I had to grind out smooth before I was able to attached the Heli-Cal coupling. From other threads I've read, CNC Fusion know about this, but I don't know why they don't fix it. I can't image it being an expensive tool. I would have paid the difference to have it in the kit.
    Attached Thumbnails Attached Thumbnails CNC Fusion X2 Ballscrews, Y screw is too long.-cimg1396.jpg
    Dec 2006
    My kit I just got from them fit my X2 perfect. Although I've seen HF mill bases have large amounts of flash on them. I had to grind mine back because nothing fit it really. Including the stock screw would bind occasionally. Their kits was top quality on my install.
    Registered Crevice Reamer's Avatar
    Mar 2008
    Quote Originally Posted by spaceballs_3000 View Post
    I hope you didn't grind that 1/4" off of the BALLSCREW! If you did that, then you cut down the already miniscule X2 Y travel by 1/2 inch. Better to grind the base to make room for the ball screw end.
    Also, you may need to install some kind of "hard stop" to prevent the Y ballscrew from coming out of the ball nut and spilling bearings all over the floor.
    CR.
    Jun 2004
    I had the same problem with Hoss' CNC conversion. The Y screw was too long according to his drawings. I just ground out a pocket in the base for the screw to fit. I think there is just a lot of variance in the 'flashing' of these as TheWolf stated.
    Apr 2008
    Quote Originally Posted by Crevice Reamer View Post
    CR.
    Yeah I didn't think about that until after I did it
    Oh well...
    no need for hard stop, it hits the base and stops on it's own.
    Mar 2008
    ...no need for hard stop, it hits the base and stops on it's own.
    Yeah, you're right! Been a while since I was inside the X2. I was thinking of the X3.
    CR.
    1. Syil X3 CNC or X3 + CNC Fusion + etc
      By iamscottym in forum Benchtop Machines
      Last Post: 05-11-2008, 06:43 AM
    2. CNC Fusion Kits
      By Regnar in forum Benchtop Machines
      Last Post: 04-06-2008, 06:00 PM
    3. CNC Fusion kit questions
      By Hellbringer in forum Benchtop Machines
      Last Post: 02-05-2008, 01:17 PM
    4. CNC Fusion
      By Memran in forum Benchtop Machines
      Last Post: 04-03-2007, 07:20 PM
    5. CNC Fusion kits
      By Redline in forum Benchtop Machines
      Last Post: 11-01-2006, 07:22 PM
