Old 05-04-2008, 10:23 PM
spaceballs_3000's Avatar
spaceballs_3000 is on a distinguished road
Recommend Fuse rating for Kelinginc KL- 7212
I like to add an fuse to the power supply.
Any Fuse rating recommendations for Kelinginc KL- 7212 powersupply? Note I'll be using 120vac.
KL- 7212 powersupply spec, unregulated Power Supply 860W, 72VDC/12A, Single Rectifier Module,120VAC or 230VAC.
Thanks.
Old 05-05-2008, 09:28 AM
rgammage is on a distinguished road
Hello
I assume you mean a fuse on the input side. That given, the fuse needs to be larger than
860 (watts) / 120v (your input volts) which gives 7.2 Amps. Most power supplies take more current at switch on ( known as inrush current) and also you do not want the fuse to blow regularly. I would fit an 8 Amp Slo-blow fuse (if you can get them) or a 10 normal fuse.
A Slo-Blow fuse will not blow for several seconds at start up even if the current is several times the rating but will blow in several minutes if current is taken at the rated current. Similar to a thermal trip which you mich also like to check out.
I hope this helps
Richard
Old 05-05-2008, 05:42 PM
Originally Posted by rgammage View Post
Hello
I hope this helps
Richard
That give me a good idea of what I need to do now.
Thanks Richard!
KelingInc, you are the best. alexccmeister Vendor Discussion 4 01-19-2009 11:39 PM
KelingInc and Mach3 trouble Normann Automation Technology Products 9 09-26-2008 11:12 PM
Newbie- Kelinginc for steppers and controller haku DIY-CNC Router Table Machines 2 04-18-2008 01:10 PM
Kelinginc question lovebugjunkie Commercial CNC Wood Routers 2 08-11-2007 03:00 PM
