Old 05-04-2008, 01:20 AM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
New Grizzly Machine! Looks nice!
Browsing through my new Grizzly 2008 mag and came across this new Mill they just released. All I have too say is wow! I think it's pretty badss. It sure looks like it includes some really nice features. It may not be necessarily be benchtop But I still wanted too share here with you all!
Look for yourself:
Description
The latest addition to our line of milling/drilling machines sports a dovetail column with a power feed. That’s right! No more cranking the head up and down for tool changes or clearance, just push a button and save yourself the trouble. And there’s more great features, too! A cast iron stand is supplied that has a coolant return trough. This adds mass and convenience to an already exceptional gear head mill. Check out the specs and don’t forget the tooling. You’ll want to fire this puppy up the minute it’s delivered!
Specifications:
* Motor 1-1/2 HP, 220V, single-phase, TEFC
* Spindle taper R-8
* Spindle travel 4-3/4"
* Max. distance spindle to table 16-1/2"
* Max. distance spindle to column 10-1/4"
* T-Slots 4 @ 2-1/8" centers, 1/2" studs
* Table size 9-3/8" x 32-1/4"
* Table travel (longitudinal) 21-5/8"
* Table travel (cross) 7-7/8"
* Vertical headstock travel 16-1/2"Max. drilling capacity for cast iron 1-3/4" Head tilt 90° R & L
* Number of speeds 6
* Speeds 120, 210, 340, 670, 1180, 1970 RPM
* Overall dimensions 68" H x 33" D x 46-1/4" W
* Approximate shipping weight 944 lbs.
Features:
* All steel gear drive
* Dovetail column
* Oil filled gear box
* Manual and motorized headstock lift system
* Table power feed
* Integrated headstock control panel
* Tilting headstock
* Coolant troughs in table and base
* Work lamp
* Cast iron stand
I think for the price and size, it's great. It would be very fun too CNC and enclosure it. Looks like a nice machine.
Price after shipping!
Your Price:** $1,971.50
-Jason
Old 05-04-2008, 08:50 AM
pete from TN's Avatar
pete from TN is on a distinguished road
I saw that one too.....
It looks like a nice machine but I think the Lathemaster has the same features and power head lift for a lot less money. The biggest problem I think is the part that mounts the head to the column is kinda small. If you look at the lathemaster machine and the Industrial hobbies machine the ring and mount are much larger and heavier. Besides Bob at Lathemaster is a super guy and has taken care of me and my Lathemaster mill for quite a number of years now. If you want a heavy duty benchtop mill in this class it is really either the IH or the Lathemaster I think and the IH is pretty expensive altho it does have a longer table. Mine has power x feed and power head feed. The head feed is a real nice feature because if you crank that head up and down a few times you will get tired of it real quick as it is pretty darn heavy. The only way up from here is really to get a nice knee mill. That is the point I am in now, trying to decide if I should sell my beloved lathemaster and get a knee mill to cnc or just cnc my current mill. There is a lot to be said for the bedmill setup tho when cnc because there is no reason to extend the quill if your mill head can travel up and down a huge amount and it is much more rigid. With the knee mill you have a heavier duty machine but under cnc you wil probably end up with a quill driven z axis which can introduce flex under heavy milling loads. I will probably end up doing my Lathemaster because I have seen and talked to several people who have them cnc and are very happy with them. I have to say that this machine has never let me down even under some pretty heavy abuse and initially with my inexperience causing some unnecessary stresses. It cuts aluminum and steel with little problem and is on a large welded up rolling stand I made so I can put it anywhere in the shop I need to. I just also bought a used rf30 round column mill for a very low price so I will still have a manual mill to play with while I am making this one cnc. Peace....
Old 05-04-2008, 11:11 AM
I just check your mill out, looks dang nice If I were you, I would CNC that for sure. If I do a get a new mill towards the end of the summer or whenever, it would probably be your Lathemaster or this Grizzly. But your Lathemaster is cheaper and that "saved" money could be put towards CNC'ing it
Interesting....
-Jason
Old 05-04-2008, 12:20 PM
cjdavis618 is on a distinguished road
I saw that mill in person when I was at Grizzly's Springfield place last weekend. I thought the same thing about the rotating ring. But as I got to looking closer, the head is bolted tight in 3 places instead of 2. My SX3 mill only has 2 bolts and in noticeably weak in that area when milling steel.
Frankly, If I wasn't there to buy my new bandsaws, I would have brought that back as well. I didn't have room though and I would have been divorced the minute I got in the driveway. lol..
My initial thoughts on the mill are the nice finish on it. This one was cleaned up very well compared to some of the other import models. And the electronics are in a very nice layout in the panel. You could just about fit some gecko's in there.
Old 05-04-2008, 01:56 PM
tmarks11 is on a distinguished road
Lathemaster doesn't seem to sell their machines now with a power head lift (nor do they offer it as an accessory). Maybe it was an option when you bought yours? Plus, the Grizzly base is definitely head and shoulders above the rest, it is a heavy duty cast-iron stand.
The only other RF-45 that I know of that comes with a power head lift is the RongFu RW326-1021 on sale for $3045 from Enco ($3200 with cheap sheet-metal stand). Add another $300 for power x-axis. PennTool also sells the same Rong Fu, also for $3200 (wthout stand or power x-axis).
The Grizzly is a steal at that price; bet it goes up $500 on January 1.
Old 05-04-2008, 01:57 PM
Oh really, well then...that solves that problem Thanks for the information. Does it come with the x-axis power-feed? Either sell it or can those be used for CNC, converted I mean.
It looks like a great machine, it really is making me interested lol
-Jason
Old 05-04-2008, 06:34 PM
What base?
are you referring to the x and y base unit or the stand it is sitting on? My Lathemaster came with the power head feed and I am sure if you ask nice Bob will get you one too. Basically the Lathemaster is the same machine as the IH but without the longer table. As far as the three bolts holding it on to the two, The real difference lies in the height of the z axis slide. THe Lathemaster and the IH are over 12" long whereas the grizzly at least in the pictures looks much shorter nevermind the small ring to tilt the head. My lathemaster mill also has two ground pins that locate the head that are drawn in with some small bolts. That head is not goin' anywhere beleive me. Not saying that the GRizzly is not a decent machine just that for less money you get a more rigid machine. I did not buy their stand altho it looks like most of the stands that can be purchased with these type mills, instead I welded a heavy wall rectangular tube stand for it that has very heavy casters and lift dogs. The only regret I have with my Lathemaster mill is that I purchased it wired for 110v thinking I would be happy with that but I wound up rewiring it for 220v sp which actually got rid of a lot of the wiring and relays as well as the large box that housed the control units. I hope to use that same box now to house my CNC controller etc. I am gonna put the x axis power feed unit I have on it now on my new round column rf30 and use that mill as a manual one and maybe build a dro for it. Should be fun!!!! Peace all...
Pete Matos
Matospeter@charter.net
865-363-9218
Old 05-04-2008, 08:21 PM
good to know, although I am surprised that Bob doesn't advertise power head lift as an option (although I am guessing it is alot easier to order a half a container all the same... ie. without power feed, and special order one or two at a time for the more discerning customer).
The G0484 Grizzly stand is about 300# of cast iron, definitelty a cut above the typical sheet metal mill/drill stands.
Old 05-04-2008, 10:13 PM
As far as the Quill, I would rather not have one for rigidity. I have taken the handles off of my SX3 to be able to put the head as close as possible to the part. ( But that is only for CNC. I would want it for drilling if it were manual, etc.)
As far as Z travel;
Web shows
Grizzly Max. distance spindle to table 16-1/2" Spindle travel of 4 1/2" quill travel. X and Z power feed. The size of the Slide is a good bit smaller though. That would be a weak spot.
IH shows 22.25 for the same. Also it is $600+ more. No power feed. Quill travel is 4.75"
Lathemaster shows 17" on the Z headroom. And is $1395 with no z power feed or X powerfeed. Quill feed 5"
Old 05-04-2008, 11:05 PM
My take on it is this.....
that cast stand is for sure nice but for cnc which is the main reason for me buying this machine, I am gonna make a nice enclosure and coolant tray to add to the already heavy duty steel stand I welded up so the stand for me anyway is a non-issue. The IH mill is very nice but the 22.5" of z travel is over the top and I doubt you will ever need that much travel anyway. I have a very large Yuasa super accra dex dividing head and with the chuck on it sitting horizontally it is quite huge and even with only 17"( which I think is very conservative) I can still get my drill chuck and my longest drill bit over about anything I might want to put in the dividing head's chuck. With 5" of quill for drilling it is no problem to get about anything you would expect to machine on a mill of this size on the table and access it. The only real machining envelope issue with my machine is the y travel is a bit short but I am working on that..... I agree that no quill travel for rigidity is the way to go on a cnc machine and that Is why I chose the dovetail column machine to allow that setup. For the money, with a x-power feed unit and the machine for the price he is selling it you would be hard pressed to get more machine for less or even slightly more money. Besides to be honest if I were to spend near $2k I would not be looking at a Mill like this anyway, I would go straight to a fullsize bridgeport clone anyway. I looked around for some time before I laid the money down on my machine and despite the grizzly being not available at that time I still think the Lathemaster is better. Bob Bertrand is a super good fella and has taken care of me with replacement parts when I broke something even when it was really my fault. JMHO tho....Any of these mills is a nice addition to any hobby shop and once cnc'd might even be useful for light production or prototyping work. That is where I am headed anyway. Peace all...
Pete Matos
865-363-9218
  #11   Ban this user!
Old 05-05-2008, 12:36 AM
I think the Lathemaster is the better choice. This will be a short post as I have things too take care of, but more too come.
-Jason
  #12   Ban this user!
Old 05-05-2008, 10:37 PM
ViperTX is on a distinguished road
I believe this is pertinent....ENCO is offering their RF45 equivalent mill for $1495 with free shipping.....if I had found a decently priced CNC kit for it besides the IH CNC kit, I would have bought it instead of the Grizzly X3 that I just ordered.
Any opinions on the Grizzly g4016 lathe or other Grizzly lathes? DublD General Metal Working Machines 3 11-26-2006 01:23 PM
Hot lead on a possible nice buy. Alan T. General Metal Working Machines 1 07-08-2004 11:07 PM
Nice machine CNCadmin DIY-CNC Router Table Machines 6 07-04-2004 01:22 PM
Nice kits CNCadmin Steam Engines 0 12-14-2003 12:54 AM
