Old 05-03-2008, 11:10 PM
bilinghm is on a distinguished road
Boring pulley for motor shaft
I need to bore a pulley to fit on a motor. The motor shaft is exactly .5". Question, what size should I bore the the pulley ID for best results? Maybe .002 smaller?
Thanks in advance, Bill
Old 05-03-2008, 11:44 PM
Boring 0.002" smaller is too small. For motor pulleys go for a size-for-size fit or slightly larger; i.e., bore 0.500" -0.000" +0.001".
Boring 0.002" smaller would make it impossible to get the pulley on without heating it and shrinking it on....then you would never get it off!!!
Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft DonW DIY-CNC Router Table Machines 7 03-17-2008 04:58 PM
Alternate Motor Pulley? giantcake Shopmaster/Shoptask 2 01-02-2008 07:35 PM
timing pulley for for stepper motor derkiow Stepper Motors and Drives 1 03-10-2007 04:10 PM
Motor pulley JWOOD Fadal 9 03-31-2006 04:45 PM
How to removing a pulley from a motor ?? RotorRouter General Electronics Discussion 6 11-12-2005 08:32 PM
