Old 05-03-2008, 10:11 PM
cncuser1 is on a distinguished road
Auto-lubing ways for the newbie
What hardware is everyone using for auto-lubing.
Are the ways lubed only once per startup, or are they lubed at timed intervals?
What do I look for, for an X2 type machine?
Is air pressure used to move the lube or does the hardware have some sort of internal motor or solenoid to push the lube.
Old 05-04-2008, 12:13 AM
blades is on a distinguished road
The best (and simplist) I've seen is a typical one-shot lube system with a spring-loaded plunger pump that you pull up, and it slowly retracts back down, pumping lube to the ways & screws. I've seen this setup put on Bridgeports, mostly.
Here's a cheap one:
http://cgi.ebay.com/Bijur-Lubricator...QQcmdZViewItem
Old 05-04-2008, 05:15 PM
What do the Seig Super X4+ use as lubing machanics?
Auto tool changer Q from newbie cncuser1 General Metal Working Machines 4 11-16-2007 06:25 PM
Newbie in so many ways KKutt Servo Motors and Drives 2 05-15-2007 06:06 PM
Lubing ballscrews? mayhugh1 Linear and Rotary Motion 1 03-07-2007 05:47 PM
box ways heilcnc General Metal Working Machines 0 03-02-2005 07:44 PM
