| CNC4PC C10 breakout board. Just FYI. Got the CNC4PC C10 board, notice a lot of flux still on the bottom of the board. Cleaned with flux remover, then noticed two solder joint that were badly soldered, in fact one was a cold solder joint. Anyways just used my soldering iron and fixed it. But having a lot flux paste on the bottom of the board can cause issues, I have built hardware devices where they will fail if I leave flux paste on them. |
| Flux is always bad to leave but I've seen worse. I once bought a cheap wired telephone to use as a backup in case of a power failure as none of my cordless would work without power. I brought it home and tested it. Everything was fine so I wrapped it up and stored it in with me emergency stuff. About a year later, I needed it but it would not work. I had to use cell phones. After the power came back, I was going to toss it but decided to open it up. I found a lot of some kind of flux on most of the connections and a piece of springy folded metal under a large cap. This capacitor had been badly soldered and when the joint failed, the piece of metal pushed the capacitor up and broke the connection. I took out the piece of metal and soldered the capacitor back in and the thing worked again. Talk about engineered to fail...
__________________ Been there, done that, got the tee shirt... |
| My c11 went up in small flames last week Got another one yesterday, 10amp solid relay not working ![]() -Jason |
| Also if you got lots of flux paste on the board, go to ratshack grab some flux cleaner (couldn't hurt.) Last edited by spaceballs_3000; 05-02-2008 at 04:29 PM. |
| CNC4PC multi board | krymis | General Electronics Discussion | 23 | 07-28-2008 08:49 PM |
| CNC4PC C10 Breakout Board and C6 Speed Controller ? dont want to fry it | maxboostbusa | Benchtop Machines | 2 | 01-24-2008 05:33 PM |
| 2020 drive with cnc4pc breakout board | najnielkp | Servo Drives | 4 | 02-28-2007 12:34 AM |
| cnc4pc multifunction board Rev 2 | jguillen08 | General Electronics Discussion | 4 | 01-13-2007 10:27 PM |
| cnc4pc relay board question | Stuff-Builder | General Electronics Discussion | 14 | 03-17-2006 10:17 AM |
