Old 04-28-2008, 02:18 PM
KTP KTP is offline
Gold Member
KTP is on a distinguished road
junk box precision mill
Hi guys,
I am trying to throw together a small precison mill that I can loan out to friends. I want to use only parts I already have, because I need to reduce the volume of junk in the house/garage. I have made some preliminary cad drawings and will be using three KR-33 series linear stages (the cute little ones with a ballscrew and carriage in a steel frame, with nema 23 mount) supplemented by linear rails and carriages in all three axis. I happen to have just enough rails and carriages except that I need one more IKO LWHS25 carriage for the x axis. The complete part # is LWHS25 SL on the carriage and LWH25 SL on the rail. Anyone have one to sell or trade?
I will post pictures of the build as I go...about to start machining the baseplate today or tommorow. I scored a huge slab of mic6 ground plate at boeing a few years ago (36 inch by 44 inch, 1 inch thick) so that should mostly do me for metal. Total travel will be 10 inches Y, 14 inches X, and 12 inches Z. I plan on using nema23 brushless servos by API motion since I have 4 of them already. They are rated at 1.6Nm stall torque, so quite peppy. The machine should do around 500 to 1000 IPM rapids, maybe a bit more.
I am thinking of using a Taig headstock and a 1kW brushless motor for the spindle. I have a motor that can do 5000 rpm, and gearing up 2 to 1, should put me at the 10000 rpm max for the taig. Plus, since the spindle motor will be under servo amp/computer control, it can do interesting things.
I am going to machine a thick, wide dovetail into the baseplate so the z-axis can be quickly removed and attached while maintaining alignment. This will allow me to split the machine up into two fairly heavy, but moveable parts when loaning out to friends or taking on the road. Hopefully I can keep each piece under 150 lbs or so.
Old 04-28-2008, 05:37 PM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Sounds like it will be a cool project, please post pictures.
-Jason
Old 04-28-2008, 09:25 PM
Rodm1954 is on a distinguished road
A mate and I are finishing off a gantry machine using similar items and for exactly the same reasons. Scaled down from what you have in mind but very keen to see what you come up with. Used a KR33 on Y and a KR26 on Z and a ballscrew and rails on X. It started off as a portable machine but has turned into a moveable category.
I have some KR46's on the shelf that I would like to make a mill from so keep the posts and some photos coming.
cheers,
Rod
Perth, Western Australia
DIY CNC Precision Mill Design&Build RogerRetro General Metal Working Machines 12 03-19-2008 03:09 AM
Journeyman 320- convert or junk it? Tom Curran Tree 1 12-11-2007 12:55 PM
Junk foam CNC? ls7corvete DIY-CNC Router Table Machines 23 03-15-2007 11:29 AM
Junk Physics flakker Benchtop Machines 8 10-21-2006 07:43 AM
precision servos (digital) vs. precision stepper (<3.6degree step angle) bennyben Servo Motors and Drives 6 03-05-2004 11:11 PM
