| This is making my head spin! (spindle control question) Beginner alert! (somewhat passed newbie) I've finally gotten my X2 (HF-44991 mini-mill) cnc'd. Now I'm ready to tackle the speed control, but don't know where to start. I've read about the C6, the C10, the DigiSpeed, the Minarik, the parallel port, KBIC's, SCR's, ad nauseam... I've opened up the back of the mill's box and found a board labeled Sieg DC Motor Control. On the board states "Sieg-Famous", also states "Sieg-FC350SMD" AND has a stick-on label covering these both up that says "05011027". I don't know whether it's an SCR or a PWM board or whatever. I've viewed pictures (mostly without labels), videos from the web (where someone points in the general direction of what they're talking about), read technical documents about things I know nothing about. I just want simple instructions with labeled pictures! LOL! Can someone show me how to do this? I would really appreciate your time in putting something together that all of us could benefit from. Thanks in advance! (wanting my spindle to spin, not my head) |
| so far my experience is that the c6 board wont work with the sieg d.c. spindle control. I think ill do some more testing today and see if i can get it to work. but the way that it is supposed to be wired make the spindle run at full rpms. so i am looking at a new dc control from baldor or kb electronics. |
| http://cnc4pc.com/Tech_Docs/C6-Varia...ual%20Rev5.pdf mini mill electronics enclosure: http://www.grizzly.com/images/manuals/g8689_m.pdf Looking in the back of your mini mill electronics box: At the upper left there are 4 wires connected. From right to left they are P1, P2, P3, P4. Get a C6 board and 12 volt power supply from cnc4pc.com set it for 10 volts max output. Connect it to P1 and P2 as shown in the X3 wiring diagram. Connect and fine tune your Mach 3 as illustrated in the manual. It's that simple. X3 wiring diagram: http://cnc4pc.com/Tech_Docs/Sieg_X3.pdf Or you can use the "replacing a potentiometer" section of the manual. Remember to keep your 12 volts separate from everything else. CR. Last edited by Crevice Reamer; 04-26-2008 at 04:19 PM. |
CR. Last edited by Crevice Reamer; 04-26-2008 at 04:21 PM. |
| take a look at this thread: X2 Speed Control Pot. Voltages we both are having this problem, the c6 works as described, puts out a voltage of 0-~11.9vdc when the speed is changed in mach3, i am using the 12 volt supply that is used to run the little fan in the back of the sieg x2 mini mill. but the d.c. speed control works backwards, in that it increases the speed as the voltage it senses at the pot decreases. |
| Yeah! I just answered this in that thread. Should have come here first I guess. CR. |
The DigiSpeed-XL will work with the Seig X2. Have a look at; http://homanndesigns.com/store/index...&products_id=2 Cheers, Peter.
__________________ ------------------------------------------------- Homann Designs - http://www.homanndesigns.com |
| Slow spindle spin-up on Super X3 | StennCU | Syil Products | 2 | 04-01-2008 01:26 PM |
| Using Flashcut CNC Spindle rotate card control to control laser power | pyroplotter | FlashCut CNC | 0 | 10-15-2007 10:46 PM |
| Making a boring head | rigo430 | Metal Working Tooling | 6 | 09-20-2007 11:08 AM |
| how to control laser head movement from PC | nicklv | Laser Engraving & Cutting Machines | 2 | 03-01-2007 09:40 PM |
| making a control box... | bryanrabb | Xylotex | 5 | 09-08-2006 06:49 PM |
