Old 04-26-2008, 12:12 AM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Shop could have gone up in flames
OK so check this out! After the disgusting officiating by the Refs during the Ranger game I went too shop too vent. As you guys may know, I have been building a new enclosure for my Taig. The shop is a damn mess so I started cleaning up. I'm sweeping, putting tools away and my back is turned too my mill/computer area. All I hear is "Pooooooooooooof", I turn around all freaked out and my C11 BOB from cnc4pc is in flames! FLAMES! It's sparking, small flames and smoking. I immediately run over and just pull all plugs out of the wall.
So, I now look at the board and am in disbelief, everything was shut off. Computer off, C11 unplugged from comp, no power too it. The only thing plugged in was my coolant plug, but it's been plugged in for weeks now.
All I have to say is regardless if the the coolant plug was in, this should not have happened. Oh that just reminded me, my pump better not be damaged because it actually started too go on and coolant went all over the shop. Which gets me too another thing, THANK GOD i was in the shop. If I was not in there who knows what could have happened. I have papers all over my desk, the board is in a case that is right against the sheet-rock'd walls.
I'm utterly disturbed right now. I can't believe what happened. I need my machine running this week! All I have too say is that I hope this gets taken care of. I don't find myself responsible for this at all either. This too me is 100% a board malfunction where something went bad and allowed the board too fry and pass voltage through it.
I'm feeling sick....
Old 04-26-2008, 12:18 AM
Stepper Monkey is on a distinguished road
Damn. That sucks. It was indeed fortunate that you were there.
I have seen a number of complaints on here with CNC4PC boards blowing out rather frequently, but actual >flames< is something new - I wonder if CNC4PC started getting their electronics from MaxNC or something....
Old 04-26-2008, 12:29 AM
Hhahah Stepper, I am really nervous because I cannot afford a new board when this was clearly not my fault and I know the board is damaged. My god, if I was not in the shop.....
There were flames.
I hope this gets resolved, I emailed Arturo.
Old 04-26-2008, 02:34 AM
Lexx0001 is on a distinguished road
It will be interesting to see how this one turns out. I've seen switches that are underrated for the current they carry. They arc and spark and if the contacts get bad enough, don't open when you turn them off. So then they have voltage and current going thru them, they get hot, and so on. Is that what happened here? I don't know. My first thought would be that something conductive, like fluid, metal shavings, whatever floated in and settled on something bad. But if everything was off, the voltage should have been stopped at the switch. Unless they are using a spst switch and cutting the neutral and not the hot. I don't think that would be up to any code. It's a mystery shrouded by a conundrum wrapped in bacon. Was the board damaged? What part got hottest?
lol at the maxnc comment. From what I understand they wouldn't have enough power to actually start a fire. Smolder maybe. I'm just joking, I have one, it works fine for me.
Old 04-26-2008, 05:42 AM
The Blight's Avatar
The Blight is on a distinguished road
I too have noticed several people blowing up their CNC4PC boards (doesn't matter what type).
Was the board connected to your computer? Might have broken that one too.
Old 04-26-2008, 06:09 AM
No, thank god. Thats the thing, nothing was plugged in but the coolant pump: the board controls my pump with m8 and m9 and I leave it plugged into the outlet of my strip because I have not found the need too unplug it. It does not say anywhere in the manual that you must unplug anything.
No shavings, coolant or anything on my board. Just heat I guess......
I'll take a picture: about an square inch was damaged, not a huge area, but still damaged and I'm not happy about it.
-Jason
Old 04-26-2008, 09:13 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Sorry to hear that. I think Arturro will take care of you though. I kill all power to my shop when I'm not in it. Circuit breaker takes care of that. I have been doing it that way for about 10 years now and it gives me some peace of mind.
You may have broken the wrong wire going to your relay. Left the hot @ full power all the time and then switched the neutral. If that hot finds another ground somehow, it's on then.
I will have a master switch in my system that I have to switch on to even allow the coolant pump to work. You might consider the same.
Keep us updated. I am considering a BOB with relays on board from them.
Lee
Old 04-26-2008, 10:21 AM
hybidder is on a distinguished road
I'm glad you were there when it happened and averted any serious damage.
A couple of you have mentioned hearing of other problems with the products could you please be specific or give links?
Old 04-26-2008, 02:49 PM
Al_The_Man's Avatar
Maybe this is a good time to remind future builders that if you short circuit normal Machine tool building standards, bad things can happen.
Some quick ways of doing things only result in low/under par performance, and this doesn't usually result in serious damage.
I am referring to putting all electrical/electronics in an suitable enclosure, wiring with suitable circuit protection.
And if an accepted E-stop circuit and disconnect is implemented, it will stop these potential dangerous kinds of things occurring.
If the low voltage electronics are kept live, at least a properly implemented E-stop will disconnect all high voltage power circuitry, when unattended.
And a sealed enclosure contains any fire hazard.
Old 04-26-2008, 05:05 PM
Would a ground fault interrupter work to stop things like this or would that be opening up a new can of worms?
Old 04-26-2008, 05:11 PM
Al_The_Man's Avatar
Not necessarily, but it would help, and sure not make it worse.
But a GFI only works when the circuit is referenced to ground.
  #12   Ban this user!
Old 04-26-2008, 06:28 PM
goofin is on a distinguished road
hey guys go on ebay and look up napco p801 alarm systems. they are cheap and easy to use. you can hook up smoke and heat detectors plus have 6 zones for burg.
Phoenix Rising From The Flames Mr.Chips DIY-CNC Router Table Machines 21 01-20-2009 12:25 AM
New Machine Build- New TM3 Shop! schoobie Torchmate 3 04-12-2008 01:53 PM
Smoke in my shop Twistr General Metal Working Machines 5 10-19-2007 01:58 PM
Where is your shop? wjbzone CNCzone Club House 6 06-29-2007 01:02 PM
Best cad cam for our shop??? mt92 General CAM Discussion 3 10-16-2005 03:02 AM
